Need Help on PSU
  • Need Help on PSU
    hi, I completed my Carpc few months ago. I only used it few times (Dont drive car offend). I have been using it with an Power Inverter since is a laptop. I purchased a VoomPC+Mini-Itx. I want to know how I can used a Power Inverter or M2 Psu to hook it up the car the most efficient way? Anyone with ideas please post. thanks
    Here is what I have done:
    Get the PSU connect it to (+12, gnd, acc) and then to carputer?
    My CarPc Blog (<This is outdated. I have updated to a fully running Carpc System)http://acurafuse.blogspot.com
    not competely sure all of it got translated correctly, but here is what i think i understand:
    you are using a inverter and a laptop setup now
    you want to use a m2, with a carputer in a voom-pc case, and are wondering if the m2 connects to the inverter somehow.
    the m2 will take the place of the inverter-- just hook up a fused power cable from the battery, a ground, and a acc line and the m2 will work fine.
    next project? subaru brz
    carpc undecided
      Thanks, exactly what I needed to know.
