4 pole push button switch, in on or off position
  • 4 pole push button switch, in on or off position
    Anyone know where I can get a push button switch that has 4 poles (places to wire to)? It needs to be either in the on or off set.
    I am not sure which I need. It will be for replacing the on/off and eject buttons on my xbox....should i go with an on or off position momentary switch...
    RADIO SHACK does not sell a four pole switch.
    Thanks,
    JMM
    Re: 4 pole push button switch, in on or off position
    I'd slaughter an old atx-case or a laptop.
    My cars
      I think you already solved this problem, but you're looking for a 2-pole momentary switch (4 or 6 pins). The 6-pin will probably be more common.
      Any electronics store should have this, they are not uncommon.
      case buttons that are used for power/reset/turbo usually have 6 pins, meaning pins 1-2 and 4-5 are connected when the switch is open, and 2-3 and 5-6 are connected when the switch is pressed.
      IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
