Double power and double ground on OPUS 120W?
  • Double power and double ground on OPUS 120W?
    I just got my OPUS 120W PSU in the mail today and I'm confused by the 6 wire pigtail and can't seem to find the answer here.
    Manual says:
    Blue/White - "On/Off of amp, LCD, etc." Does this mean this is the delay, anti-thump on/off wire?
    Red - "IGN/ACC switch." This one is obvious
    2 yellow - "+ from battery." Obvious, but why is there two and why are they only 16AWG when the manual suggests 12AWG or larger?
    2 black - "- from battery." Obvious, but again, why two?
    PROGRESS:
    Hardware: 100%
    Software: 99% - Always upgrading and improving.
    Installation: 100%
    WORKLOG:
    2005 F-150
    Red Hot Chili Peppers - Hump De BUMP.
    PROGRESS:
    Hardware: 100%
    Installation: 100%
    WORKLOG:
    2005 F-150
      And isn't 2x16 = 12?
      One connector can't handle the lot/maximum....
        As to the question of "why", shouldn't you contact Opus? They're the ones that designed the thing.
        How about the Wiki?
          Perhaps, but I'm still waiting on an e-mail back to answer my question if the can ship using USPS instead of UPS. I ended up not worrying about it and ordering anyways.
          So I guess that means I take a 12AWG from the battery and but splice it to the two 16AWG wires? That was my best guess but I wanted to make sure anyways.
          PROGRESS:
          Hardware: 100%
          Installation: 100%
          WORKLOG:
          2005 F-150
            i think they designed it so that it could use the standard molex wires. the two wires being the next best thing to one thicker wire. Just go ahead and hook them both up. think of it as adding more lanes to the electron highway i guess
              On mine I tied the two to one 10AWG wire. Made it WAY easier for me.
              After a 2 year break, I'm back! There are so many new and familiar faces here!
              New vehicle, new ideas!
              Chryssi - The Changeling CarPC Project
                Ok, thanks everyone. That is what I'll do. Means only trying to get one wire through that grommet in the firewall. That should keep a few coins out of the curse jar.
                PROGRESS:
                Hardware: 100%
                Installation: 100%
                WORKLOG:
                2005 F-150
                  OMG, You have one of those?
                    Haha, no I don't actually, but if I did...
                    PROGRESS:
                    Hardware: 100%
                    Installation: 100%
                    WORKLOG:
                    2005 F-150
                      What about the blue/white? Was that the delayed wire that goes to the amp for anti-thump? Can/Should I use it to power the monitor or use something else?
                      PROGRESS:
                      Hardware: 100%
                      Installation: 100%
                      WORKLOG:
                      2005 F-150
                        The Blue/White wire is the 12v delayed output for turning on your amplifier or other additional equipment. Don't use this to power devices, as it has a 0.75A internal fused line.
                        2003 HCH Work Log
                        - Official OpenMobile Builder/Tester
                          the remote wire on my opus was not enough to turn on my amp. I wired my amp turn-on right into one of the 12v outputs like a yellow hard drive wire. Very low, bearable thump. I have the two powers into my distroblock and the two grounds into another distroblock, and there is only one wire through the firewall.
