Where to wire to
  • Where to wire to
    I am putting this under power supplies because it is power-supply related. I'm not sure if there is a better spot for it.
    In my car, Subaru pre-wired a connecor under the dash which is essentially a carputer enthusiasts wet-dream come true. It has power, IGN, ACC, Vehicle speed, backup light and various other circuits all in one nice little plug.
    I am thinking that the easiest thing to do would be to connect the carputer into this.
    The BATT+ wire is fused at 7.5 amps and appears to be 16 AWG wire although I am not sure. There is also a vehicle ground wire in this connector.
    My Atom based carputer pulls less than 3A and will be installed quite far away from the eventual distribution block for the audio system.
    What, if any, are the drawbacks to using this connector to power the carputer? Can the carputer's power supply safely be connected to the ground lead in this connector or should it be grounded somwhere else? The carputer's audio connector will feed audio equipment that will be grounded elsewhere.
    Your best bet is to ground all your audio equipment at the same point.
    And if that connector is 16awg, I wouldn't use it for the PC, even a low-power Atom-based setup.
    While it is possible that the wiring could handle the load, I wouldn't trust it. It's safer to run new wires so you are 100% certain of their load-bearing capability.
    How about the Wiki?
      Thanks for the input. I'll have to check the guage to be sure. Why would it be fused at 7.5A if a 3A load is risky?
        The fuse is there to protect the wires, not the equipment.
        How about the Wiki?
          Thanks, I understand the point of fusing to protect the wires.
          What I am saying is if the wires aren't capable of handling 3A for the carputer, why would Subaru fuse it at 7.5A?
          (Not trying to question your experience, just trying to understand why it would be unwise to use a factory installed connector which appears to be there specifically for aftermarket equipment).
            I don't know whether that wiring harness is capable of a 3A load or not.
            You don't know, either. If you did, you wouldn't have asked.
            So rather than take guesses, you are better off running your own power wires that you know beyond the shadow of a doubt will handle the load you will put on them.
            Then there will be no question whether your wiring is sufficient.
            If you use the existing fused circuit and the wiring is not sufficient, then you have the situation that 2K1Toaster has made famous with his awesome MSPaint skillz:
            How about the Wiki?
              Darquey - you have been told...
              .... that I like that drawing...
              (And I needn't applaud "fusing is for the cable" etc etc ....)
              Maybe because 6A or 7A is used for something else?
              Most seem to want to provide their own supply for things like 'putors & audio straight from the battery (through a fuse or circuit breaker, and maybe through a relay). I do!
              This is to ensure adequate supply that is independent of vehicle systems.
              It is usually simpler than researching the vehicle's system.
              And is is the next step if you find that using existing wiring has problems.
              (And it should not effect vehicle warranties etc.)
                I take no credit for that drawing. That is all from 2K1Toaster.
                I just make sure that it is used appropriately, and as often as possible.
                And I must say that I love it, too.
                Especially the way the guy's eyes are bugging out when his car is on fire.
                How about the Wiki?
                  I've got all the wiring diagrams, nothing else appears to be on that wire or fuse.
                    Then it is your decision.
                    If it is 16AWG, you should only have ~0.04V per meter drop (at 3A load), plus whatever other path resistance/drops there are including the ground path.
                      sebberry, what year is your Subaru?
                      I'd say you can try using the existing connector, but make sure you put a fuse between your carputer and the connector.
                      2007 Camry Altise In-dash Car PC
                        It's a 2005 Outback.
