Carnetix + Mac mini power on issue.
  • Carnetix + Mac mini power on issue.
    Hey all, iv installed my mac mini into my truck a few months ago and from the beginning stages of testing everything was working fine, since i was still fabbing parts and pieces i left the power supply plugged in but disconnected the power out side (the mac pack cables ), originally it would start right up with the key and shut off no problem, i reconnected the cables to use it the other day and the power supply isnt turning on the computer but it will shut it down every time.
    Can anyone think of a reason this would occur if it was working fine in the beginning, im stumped =(.
    Which model do you have? The 2140 has a USB connection that you can use to monitor the device.
      CarNetix CNX-P1900 Ver. 2.2, with the mac mini and lilliput 10.4 connected to it.
        Reload firmware. It can get scrambled from losing power completely.
        Want to:
          How do i go about reloading the firmware? Is this something i can do myself or will i have to send it somewhere.
            Hang on, it's the 2140 that can get scrambled. Have you completely removed power to the P1900? If not, remove all power to it and let it sit a couple of minutes to allow capacitors to discharge, then retry.
            Want to:
              Iv never removed the battery power going into the power supply, iv only disconnected the output to the computer/monitor when i was doing a lot of key on and off things, i didnt want to keep booting and shutting down every few minnutes, so i left the monitor and computer off until i was finished.
              Ill go ahead and leave disconnect the power supply tonight, i wont be going anywhere until tomorrow so i guess ill just have to wait and hope for the best.
                I went ahead and gave it a try, i actually didnt drive that vehicle for a few days so it sat completely unplugged for the whole time, i plugged it back in yesterday, it flashed a few times when the ignition was turned on, the fan blew hard for a second and then it quieted down, the light for the monitor was light so it is providing power out and i can still turn on my mini manually but still have no luck =(.
                Any recommendations?
                  You need to to check to see if the start pulse is actually occurring. You can do that using a volt meter and connecting the leads to the output pins, check the 1900 manual to see which pins are which.
                  If the unit is producing the start pulse then either the cable to your mini is bad, or how ever you have the start button switch setup is bad.
                    Ill go back and double check for continuity, i just have a feeling it may be an issue with the power supply since everything was working fine initially and with out changing anything it stopped working correctly, but ill do that to cover all the bases and report back with my findings.
