Startup Shutdown controller for ION board
  • Startup Shutdown controller for ION board
    I come to the experts of mp3car.com for advice. I recently purchased the ZOTAC IONITX-A-U Atom 330 1.6GHz Dual-Core 441 NVIDIA ION Mini ITX Motherboard/CPU Combo from NewEgg.com.
    I am here looking for a startup and shutdown controller I can use to control it. You will see it has a built in 90w power supply that I will be directly hooking to the car battery but want a controller to handle startup and shutdown from the ignition. I have searched the site for something like this. I found one very nice install on a 2006 civic that has an LCD and everything but it looks like a lot of soldering to me. I would like a plug and plug setup if possible.
    Can anyone recommend a controller I can buy from the internet? ALL of the controllers google returned to me are no longer available to buy.
    being that you have the board, maybe you can answer the question that has been bothering me-- is the power adapters output 12volts, or 18-19volts dc?
    if it is 18-19 volts(i thought most of the boards with single power adapters like that were), there are the carnetix power supplys that can power it, and provide a startup/shutdown controller.
    next project? subaru brz
    carpc undecided
      Yes you are correct. It is 19v, 4.74amp output from the AC power supply. Carnetics looks like the way to go, thanks man.
        this will work too.. full automotive intellegent mode..
        http://www.mini-box.com/DCDC-USB
          AWW MAN! smaller form factor, config software, usb and cheaper. Too bad i already bought the carnetix one.
            That's awesome! I've been looking for something like this. I have a Lenovo Q150. It takes 19volts in and the manual says the closest it can be set to is 18v but hopefully that's close enough. Thanks Z0rr0!
              could this one (http://www.mini-box.com/DCDC-USB ) be used with an acer revo? I know they're 19V as well - it would be a cool solution if so - thoughts anyone?
                Actually, it looks like through software this can be set to 19v. I wonder if this could work for my Acer Aspire Revo as well. I've been using a laptop adapter with no problems so for, but I would like an auto shutdown and startup as well.
                You are never done installing a CarPC.
                  I emailed them about the USB controller and the Revo specifically - this is the response I got back -
                  The DCDC-USB is a suitable product, you can set it to output 19V without any problems. Should you need other details, please contact us!
                  Best regards,
                  Cristi Ciubotaru.
                  Sounds like we've got a plan!
                    Best regards,
                    Cristi Ciubotaru.
                    Cool! It will be a while until I can get digging back in my setup, though. If you get one and get it working well; update us and maybe show some pics of how it went! Good luck!
                      I'll be happy to do so. I've been out of the scene for a while - so I'm catching back up - a LOT has changed in the 4-5 years I've been out. So I'm just researching and trying to get a grasp on it all - so it'll be a while for me too - but things have come a long way since then - so I'm expecting a little smooth however not trouble free ride this go 'round
                        I have a Revo as well and decided on the P1900 because it also outputs the 12v my screen needs.
                          Very valid point! Thanks for the input - much appreciated!
