psu run in parallel?
  • psu run in parallel?
    i was searching for a way to converter a standard 120vac psu into a 12vdc input but it seems like more of a challenge than i thought but in my searching i came across a suggestion of possibly running 2 or more psu's in parallel to get the wattage out put i need.
    Now is this possible or am i limited to using a start up/ shutdown controller with a power inverter.
    Either way ill make it work i just want to know the best route to take.
    Why are you not using a dc-dc solution. They are so cheap nowadays, it is really a no brainer.
    1.9in x 2.9in -- 47mm x 73mm
      No to parallel supplies.
      But with 250W supplies available, what's your problem?
        he is trying to figure out how to run a xbox360 without a inverter
        http://www.mp3car.com/vbulletin/powe...g-xbox360.html
        the adapter cable he was looking at in that thread requires a power supply capable of 16.5 amps on the 12v line, and 1 amp on the 5v line..
        next project? subaru brz
        carpc undecided
          Ah - big consumers....
          Why not convert its SMPS to DC as was done elsewhere (another (old?) mp3car thread?)?
          (Though I'd probably rather stay standard and use an inverter.)
          5V/1A is no problem, but 12V/16A (regulated) - that's a fat choke on a 60A MOSFETed $5 power chip.
            I just get an inverter and be done with it. If you want to avoid some of the issues, get a true sine wave inverter
