Recommendation for laptop power inverter
  • Recommendation for laptop power inverter
    So I've been using a 150w power inverter which I purchased from home depot, to power my laptop. It has worked out great, until the other day when it finally went on me.
    I have since tried looking there again, but couldn't find it. I also bought a similar one from Home Depot, but once it was powered in the car, it flipped to "protect" mode immediately.
    I have also tried using a Carnetix various times, and have never had one work consistently. They either crap out after a month, or all of the lines don't work, so I'm finished with that money sink.
    Can any of you recommend a power inverter (or alternative way of powering the laptop in the car) which you know will work, or personally have used?
    Thanks,
    -Dave
    Originally posted by Startingline13 View Post
    So I've been suing a 150w power inverter
    I hope you win.
    My suggestion would be to look at some of the kensington automotive laptop adapters, they have a few to pick from, and they're a one-adapter-fits-all type of solution. There are different wattages available, it might be good to know what laptop you're trying to power.
    Tidder
    Try RevFE
      Too much coffee today I suppose.
      I'll take a look at those. But all I'm seeing at the moment are laptop adapters, which do not convert to a vehicle's native 12V DC output.
        Ditto.
        dc-dc is preferable since laptops etc already have a dc input.
        I recently got a smaller (I think 17-24V) 45W unit for an MSI Wind (19V) for $25.
        But you'll probably need a bigger unit (90W, 120W etc).
          http://us.kensington.com/html/13302.html
          My google-fu is strong today. This adapter does it all, wall power, automotive power, and airplane power. A DC to DC like that would be good. I'm not saying kensington is the end-all, that's just the only manufacturer I could think of off the top of my head that made a generic one.
          Tidder
          Try RevFE
            this is what i use, its been great for the past 2 years. never a problem. i cut the plastic off the cig adapter and wired direct to acc power, http://www.canadacomputers.com/produ...item_id=016109 SNO
              Yeah SNO, that's the one I remember! I just couldn't find the sucker anywhere...
              Tidder
              Try RevFE
                FTW!
                The Wall/Auto/Air is pricey, BUT considering it has AC as well, and universal AC at that! And a reasonable 90W. And good efficiency. And...
                (Though I like redundacy, hence two units else cheaper dc-dc with backup inverter & plugpacks etc - which is good when traveling in own vehicle etc, but not for lugging around manually!)
                  I got this one not too long ago for under $25 bucks and it seems to work as you would expect it to. It stays pretty cool, since I had been shopping for one with a much higher wattage than my puter even needed:
                  http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
                    Perfect! Just what I've been looking for. Thanks a lot guys. I'll order it and let you know how it goes later this week.
                      I bought the kensington adapter. Found it used on Amazon for $35. I'll let you know how it goes soon.
                        I may be reviving an old thread, but how did it work out for you?
                          Oh it was so long ago that I couldn't remember at this point, but I don't think it went very well.
                            Oh I see. Well are you still running any sort of computer in your vehicle or no?
