Can the M2 PSU use input from another PSU to power on and off?
  • Can the M2 PSU use input from another PSU to power on and off?
    I use my M2 to power my monitor and USB hub in the dash, and it's setup currently to monitor the ignition for ON/OFF...except this is draining the battery too fast (M2 + OPUS for the PC).
    I want to run a lead from the OPUS power output to the M2 to trigger the M2's ON/OFF state...
    But it's critical that the M2 stays powered the whole time the OPUS is on (including shutdown sequence) as to not interupt the USB device power...
    yes, it should work fine.
    the only problem i see is the 5sec startup delay that the m2 has...
    next project? subaru brz
    carpc undecided
      Is that delay always there, even when it is in ATX push button mode?
        i believe it is always there, and the only way to remove it was that custom firmware that someone developed..
        carpc undecided
          ****...these M1/2/3/4 PSU's are garbage!!
            Manual...
            When all config jumpers are removed, M2-ATX-HV will be in the “dumb PSU
            mode”, no ignition timing, no HARDOFF. M2-ATX-HV will send a gratuitous “ON” pulse
            to the M/B when power is applied for the first time...
            Since it's not hooked up to a mainboard, will the M2 actually power on and off then?
              that's why i use a dsatx....
              that section is just talking about the J7 jumper activity..
              that might be the way you need to set it up, but you would need to add a relay to cut power the +12v constant line so the opus can control it.
              carpc undecided
                Jeez...maybe I'll just make my own 12V and 5V regulator and forget the M2 altogether!
                Or like you say, a relay controlled by the mainboards PSU.
                  No, but can be,
                  You will need to short the PWR OK pin to gnd.
                    Done that already...
                      Of course, I plan on using Sleep mode-to-hardoff with the OPUS, so I need to power the M2 thru a relay off the 5V rail to keep the USB devices powered during sleep mode, right? Can I tap into the 5V lead feeding the mainboard for this I assume?
                        what's preventing you from using 1 psu to power everything?
                          The OPUS is already loaded down, what with 2 PCI soundcards, water pump, etc...I don't think it can handle the monitor plus another USB hub
