Where can you access the ignition power switch (IGN/SW)?
  • Where can you access the ignition power switch (IGN/SW)?
    I know there is a line going to the car stereo but was wondering if there are any other points to access this line?
    I don't really have the ability to pull the factory stereo easily, and to be honest don't want to pull out the stereo. So where else where I find the IGN/SW line to connect to my OPUS.
    2002 Toyota Tacoma
    Ryan
    New site at
    http://customcarpc.dreamhost.com
    http://home.attbi.com/~rbarr110
    2002 Toyota Tacoma Doublecab
    Go to the fuse panel. A lot of fuses only recieve power when the ignition is on (on most cars).
      Steering column too.
        Some fuse boxes have a spot for ACC or IGN.
        ACC is the position when your ignition is not on, but power is still available.
        current projects
          Re: Where can you access the ignition power switch (IGN/SW)?
          2002 Toyota Tacoma
          Ryan
          you can access the accessory wire at the cig lighter in front of the shifter. check out rbarr110's install.
          NEW complete and updated My project with 100+ pics on 7-4-03
          If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
            Thanks for the replies. Got some ideas now where to look.
            Cproaudio - The link you provided is an old one and not as up to date. Try this one and click installation on the left side.
            New site at
              OK maybe a dumb question, but will any line that only receives power when ignition is on work as the IGN/SW line?
              Ryan
              New site at
                yes, just be sure to take power BEFORE the fuse, and then add a fuse of your own
                2008 Grand Prix GXP
                • Winbook TW801 8" Windows 8.1 Tablet
                • RF 3Sixty.3
                • 4ch Alpine on factory bi-amped Monsoon speakers
                • Directed HD-Radio
                • I need to post a built log
                  No you dont want to do that You should tap it after the factory fuse. I have seen so many cars with burnt up factory wires by doing that and here's why. The back up fuse before the fuse box in the interior is the big 60A or 80A sometimes 100A by the battery. imagine if youre wire is shorted between the main fuse and the fuse you added. You're gonna have a fried wire from the fuse box to the battery. Beside The opus's acc wire takes only 150ma or .15amps. It's not going to add any more strain on the wire you tap it to. You should tap the wire after the factory fuse then add your own fuse. If you need any power larger than the factory wire can handle, you should go directly to the battery.
                  Rbarr to answer the "will any line that only receives power when ignition is on work as the IGN/SW line?" question is no. Some ign wires go to onboard computers or airbag system that you dont know about. or to the wiper. It works fine until it starts to rain. You should stick with radio, cig lighter or the clock. Since you got 2 cigeratte plugs on that panel you already took off, you can tap the acc wire there. white/black is ground on Toyotas, brown on the radio is ground too. as for ACC, Toyota change colors once in a while.
