Need powering advise please......suggestions.
  • Need powering advise please......suggestions.
    Ok so here's what I'm planning to install.
    Samsung Galaxy Tablet 10.1 with the Media Tab (HDMI Port Out)
    Gefen HDMI to Composite Scaler
    Gefen Coax digital to Toslink converter
    I'm processing sound through an Audison Bit One (which needs analog for set up, and I can go to digital or optical after that for sound. I'm hearing there are problems with the coax digital input on the Bit One so I'm choosing toslink through the converter.)
    This is all going into my car along with my audio system. I'm still researching the voltage requirements for the Galaxy charger, I've heard 19v, 5v and 2v (big differences). So that's remained to be seen.
    The two Gefen Modules are both 5v DC power inputs. Same barrel connector sizes.
    I need something that will power these units.
    I was looking at the M2-ATX, and even made a little diagram for the wiring:
    Not sure if this is correct or not.
    I'm also open to other suggestions. If you all need more info let me know I'll be happy to give you what info I have.
    This is really my last hang up to getting this going. I need to figure out this power situation so I can move forward! Bought the tablet today and will be ready to buy the rest of the components this weekend. Thanks for any help!
    I did a little test tonight with the wall charge and a DMM and came up with a 5v output.
    So that nullifies the 19v thought. So essentially I have 3 - 5v products to power up. Hope that helps. Could I take the 5v out on the M2 and run it to a relay and power all 3 pieces that way or does that make it jump to 12v instead of 5v?
    Anyone?
      Why not just use a DC PSU that outputs 5v instead of jury-rigging an ATX PSU to tap only the 5v rail?
      How about the Wiki?
        Cause I wasn't aware of one or what it is. Suggestions?
          http://store.mp3car.com/Point_Of_Loa...plies_s/10.htm
          How about the Wiki?
            Thank you. Do you have a personal preference between the two? IF so why? They basically do the same thing right? Is there a reason there is a 25.00 difference between the two? Also, could I hook up more than one device to it, or would I basically need one POL per device? Sorry for so many questions! Thanks for the link!
              that POL device is good for 15watts, or about 3A of current. you'll need to check all the device requirements to see if they can fit on a single power adapter.
              next project? subaru brz
              carpc undecided
                Ok, I'll do that. I just wasn't sure if I put 3 5v devices on, if it still put out 5v or if it would then demand 15v (5x3=15). Or does it not work that way?
                I'll look at my devices now and see. I think I'm going to make a change due to money issues.
                  No, it's 3 lots at 5V with whatever current they each have - eg 1A each means 3 x 5V x 1A - 15W.
                    Ok so according to the specs online that I found for the three devices, here's the following:
                    Galaxy Tablet - 2.5amps for charging
                    Gefen Composite Scaler - "up to 7.5 amps max"
                    Gefen Coax to Toslink converter - 500mA is all I found.
                    SO keeping that in mind, if I went with the one POV then it would be about 10 to 12 total amps. I'd say that's ok, but I'm not overly experienced with it. Would I be safer with maybe running the output to a relay and then powering the 3 devices from the relay? Or would that change it to a 12v?
                    Maybe what I'll do is just get two, run one for the tablet and it will be isolated from anything else, then I'll run the other devices off of a second one. DO you guys think, or will one be enough?
                      Ok well, now I'm going with a different composite converter, cause I'm too strapped for money. So now it's just one converter at .8 amps, and then the tablet. I think I'll be good with one POV.
                        Sorry I keep saying POV, it's POL. My apologies!
                          LOL - I thought you did mean our POVs were or reckoned... IMO trivial, but thanks for the POL correction. (Especially if anyone took it as being suspect POVs...)
                          If the devices need 5V input (as it seems certain they do), then you need a 5V supply.
                          Hence DO NOT connect to 12V. Not without a 5V converter in between. (Where's soundman's oft use pic (cartoon??) of the badly wired car about to explode? [I think it was soundman's. Apols if not.])
                          So for all 3, you need 2.5A + 7.5A + 0.5A = 10.5A. But keep in mind that for those with batteries, that should be a max draw when the its/their battery is charging (and probably only at the max when the battery is quite discharged).
                          Rounding 10.5A down to 10A means 5V x 10A = 50W output. (P=VI)
                          [ NOTE: Normally power requirements are rounded UP because you MUST supply the (full) load. But as I wrote, and as per Gefen's "up to 7.5A", that should be a (rare?) maximum. And I know there are 10A 5V supplies. Otherwise the 10.5A supply would be rounded up to whatever was available - probably 15A or 20A. But I could write a lot more on this - my assumptions etc. ]
                          Look at Charging multiple high power USB devices without cigarette lighter - at the bottom of p1 Ryven links the MeanWell 5 Volt 10A 50W 5-Pin (~$33). (I still haven't found the one I was looking for which I think was ~$25.)
                          PS... Oh - and as per a recent thread, make sure any converter is for auto use - ie, from (say) 8V to 16V etc - NOT a "12V" (to 5V) converter which are intended for 12V rails as found in PCs etc.
                            you mean this one?
                            the original credit goes to 2k1 toaster, i just distribute it...
                            carpc undecided
                              LEGEND!!!
                              I have been so thinking of that in another forum!
                              I should have remembered it was 2k1Toaster's - there is a certain commonality between Toaster's name and that pic. I wonder if it is because 2k1Toaster
                              always gives me a nice warm feeling?
