M@-ATX issue
  • M@-ATX issue
    when I turn off the truck all of the sudden the pc turns off (takes a little longer than it used to), then it will turn right back on even with ignition off and key out of ignition. Nothing has changed with the setup. setup is about 3 yrs old. This just started on its own. Is the ps bad?
    01 Burb
    http://www.mp3car.com/vbulletin/work...-suburban.html
    here is what i found, i some how lost the jumper for A setting. once i put jumper in everything back to normal.
    01 Burb
