m4 or m2 atx power supplys
  • m4 or m2 atx power supplys
    hi, whats the difference between the m4 and m2 atx power supplys, just putting together my car pc and just wanted to clear this up before i waste money on the wrong one..
    thanks daveo
    the shape and the power output. and the m2 requires a 4pin-flat to 4pin-square adapter for boards that require cpu power.
    next project? subaru brz
    carpc undecided
      hi, thanks for the reply, so how do i know what one i need or is best to use
      thanks daveo
        check one of the many online computer power calculators, and use the one that works for that power amount.
        carpc undecided
          http://www.epiacenter.com/powersim/p...mulator_v2.htm
          you could list what hardware you plan to use and we could give you some better advice
          the M4-atx is a bit more work to get mounted
          the M2-atx is usually a drop-in replacement for "dc-board" type cases; ie - 5677, 3688, GA677, etc
          m4-atx operates @ 6~30 V and puts out a peak of 250w
          m2-atx operates @ 6~24 V and puts out a peak of 160w; alternatively the high voltage M2-atx is 6~32 V and 140w
          there's other differences as well, but it would help to know what your plans are for MB, CPU, HDD's, and other major peripherals (LCD, audio card, gps, etc)
          cheers!
