Questions on Hybrid Sleep with OPUS 320 and Zotac MB.
  • Questions on Hybrid Sleep with OPUS 320 and Zotac MB.
    I was wondering what the requirements are to get hybrid sleep to work. My understanding is that when activate this option (which I did in Win 7) everything should come on instantly. It seems that even with that option selected, its hibernating instead. I know it cant be a power issue per say, because the Car PC is a fairly large dedicated battery (Kinetik HC2000). When using hybrid sleep, does it require 12V to be active? I have 55 plus USB devices, all of are mainly powered off of Hubs with a power supply. Now the PC controls these supplies via a relay off the 12v rail. Could it be that because these items go off of independent power, the PC just puts it into hibernation instead when the power is lost to those items? I mean hibernation isnt slow (7 seconds), but i would really like instant on. Also, is hybrid sleep motherboard dependent? Maybe I have an option wrong in the BIOS? What would i be looking for?
    Any advice would be helpful, thanx!
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    It appears to be MB dependent in some cases as a few just fail in that mode.
    I mentioned in another post that the MB-PSU will drop STR +5 standby if there is a sudden "large" load shift on the standby +5V rail. That’s easy to verify by looking at a USB hub that has a power led or connecting a led indicator to the 5V STBY line and seeing if it stays lit in sleep mode. Normally if hybrid-sleep mode fails it brings up the delete config message at boot. The obvious: default power button action = sleep.
    I never managed to get mine to work in that mode but others with the same MB have, so drivers and SW along with USB hardware/drivers all seem to impact.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
      I do not get the delete config message, so its most likely not even doing hybrid sleep. Just going straight to Hibernation. Im going to have to play with everything. I would love hybrid sleep, just in case the battery doesnt make it, it will hibernate instead.
      4X MK808b
      3x Perixx Touchpads
      3x 7 inch Screens
      1x Win 7 PC
        I went and turned hibernation off. I then got the error you talked about Mickz. My guess is my system has way to much going on with way to many things being powered externally. I will have to settle with hibernation, which isnt bad since the system is fairly fast.
        4X MK808b
        3x Perixx Touchpads
        3x 7 inch Screens
        1x Win 7 PC
          Yes that’s likely the problem, but in my case sleep works perfectly and Hibernate works perfectly but hybrid sleep fails every single time, even on the test bench with no external devices.
          I now have a “momentary push button” I press when hibernate is required, if I just turn the ignition off the PC sleeps ready for almost instant on with ignition on.
            I wonder if anyone else has managed to get hybrid sleep to work reliably.
            4X MK808b
            3x Perixx Touchpads
            3x 7 inch Screens
            1x Win 7 PC
              I have read a few builds on mp3car running it fine.
                Shame I am not one of them, lol.
                4X MK808b
                3x Perixx Touchpads
                3x 7 inch Screens
                1x Win 7 PC
                  Just read that Windows 8 will have blazing boot speeds. So hopefully it will be a saving grace for me!
                  4X MK808b
                  3x Perixx Touchpads
                  3x 7 inch Screens
                  1x Win 7 PC
                    I always use in my project ( see some photos in my album ) this mode. It works very stable and fine!
                    Resuming from suspend takes only about 1.5 seconds, but if the power failure occurred ( blackout ) during suspend state, the resuming from hibernate takes about 4 seconds.
                    No problem at all!!!
                      I think I am going to try an experiment on Saturday. See if the Car PC can resume from sleep. If this experiment works, then I am going to have to slightly redo the electrical wiring so the PC has a constant 12V power source running to USB (via 5V adapters).
                      4X MK808b
                      3x Perixx Touchpads
                      3x 7 inch Screens
                      1x Win 7 PC
