yet another powersupply/regulator question
  • yet another powersupply/regulator question
    I am a real newbie that happend to find your site.
    I am thinking on buying a Casetronic(Travla) C134
    It has a Built-in 60W DC power board, do i need to replace the power board with a PW70 board and/or do I need an additional DC-regulator to cope with the in car 12V in order to power up the unit safely?
    For starters it doesn't look like your link works.
    Secondly it'll depend on what hardware you want to drive.
    Thirdly the general consensus is that you need to regulate the +12V output from the PSU to be safe, however people have used it unregulated and works fine, but they're playing with fire.
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
      I have edited the link(it was a dot at the end of the url that messed the link up)
      I should now work...
      I would want to run the above PC along with a 2.5 " harddrive and maybe a 7" LCD touchscreen...
      I think that the PC above has an onboard 60W dc/dc regulator.
      Will I need an inverter or an additional DC/DC regulator.
      Is the PW70 a dc/dc regulator that can be of use in my case?
        The LCD touchscreen, if you're thinking of a DSCustoms one, will take 10-24V input IIRC so that should be safe-ish to run off the battery direct.
