I have a big problem !! I need some help with a power problem.
  • I have a big problem !! I need some help with a power problem.
    Hi
    Ok heres my equipment.
    ITX motherboard with dual core 1.8 and 2gb.
    I have the M2-atx power supply. **** side note-> Tested on a regular atx board and it powers up and powers down. It does get really hot and i noticed the green capitors are bulging on the top..(should i look at replacing those?)
    - so here is the problem.
    my motherboard only has a 10-pin power plug.
    Click image for larger version
    This is the original psu plug.
    I have a 20 pin to 10 pin plug but the wiring isnt the same as what comes from the original psu.
    Do I make the 10 pin plug match the same wiring colors as the original psu has? Or how the H do i make this work !!
    Thanks!!
