19v power supply?
  • 19v power supply?
    I'm looking at a mini PC for my car PC but see the input for them is 19v. Are there any 12 to 19v power supplies that would be suitable for this?
    Thanks.
    http://store.mp3car.com/Carnetix_CNX..._p/pwr-010.htm This will do all your needs, 19v with good amps, 12v for monitor and 5v with add-on for your hub. They work great. SNO
      Thanks.
      Just want to confirm that it will do what I need:
      Start-up:
      Soft momentary power button connected to PSU
      PSU activates 12,19 and 5v outputs then pulses the PC's soft power button (soldered into PC soft power switch)
      Shut down:
      Soft momentary button connected to PSU to shut down system
      PSU pulses PC's soft power button to cause it to shut-down
      I'll have a relay connected to my car's IGN line so that the PSU only receives +12V BATT when the IGN is ON
      IGN relay will stay on during crank, PSU will stay on
      Start-up/Shut down controlled by soft power button connected to PSU, not ACC line from car.
      Thanks.
