Do I need to use a diode?
  • Do I need to use a diode?
    I have three PT5071's that I am going to run in parallel to give me 4.5 amps at 12volts. Do I need to use diodes on the outputs to protect the PT5071's from each other? If so what?
    Thanks.
    diodes have .6v drop so if you diode isolate them, your final voltage would be some like 11.4v
    NEW complete and updated My project with 100+ pics on 7-4-03
    If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
      For shizzle?
      I mean, if I don't isolate them I will destroy them in time, right?
        Surely someone can help me answer this question.
          what the hell is a PT5071? i might be able to help you, if you state what it is!
          Ford XR6T blueprint 4.0 L twin cam turbo.
          Xenarc 7" touchscreen M10000 Audigy 2 NX
          ITX 120W PS 80gig HD, 256MB Ram, USB wireless internet/LAN
          Griffin Powermate Panasonic DVD-CDW
          Pioneer 5x7 Four way, 2x12 pioneer subz
          600watt 6chan USA audio AMP
            The PT5071 is a rather nice piece of kit. It is an ISR (integrated switching regulator) than can produce 1.5A of clean 12v from a 7-16v input. It is made by Texas Instruments, the datasheet is on their website.
            I'm planning on replacing my current L296 based power supply with a PT5071 and PT6625 based unit - pushes up the efficiency a lot and drops the heat produced.
            I can't help on the diode thing - I'll only be using one of them in my design.
            Rob
