Wanna power this laptop since I fried my system today.
  • Wanna power this laptop since I fried my system today.
    The laptop requires 15v, and I've got a car PSU that gives out 20v and another car PSU that gives out 5v. I got thinking, the potential difference between the two PSU's positive wires is 15v. Would this be ok to power the laptop?
    I`m thinking of trying it tomorrow, but somehow I get the feeling it's gonna cause ground loops and all sorts of havoc, so it might not be worth bothering.
    I'm gonna get a proper 15v PSU eventually, it's just that the E-bay auction doesn`t end for a couple of days, and I`m stuck with silence in my car since I fried my computer this morning.
    Here's how it happended:
    I powered up my computer today, except it didn`t fully power up. The power LED came on, thats about it. So I tried it in the house, and measured the voltage coming outta my sproggy.... All was good until I found the 5v rail was actually giving out 8v! So, I unhooked the sproggy, and tried a mains PSU on the computer and it did the same thing.... sat there with just the stupid *** power LED on, and nothing else. I reackon the sproggy fried the motherboard.
    I tried powering up the sproggy with nothing attached, and it gave out 12v on the 5v rail. So, just for the sake of curiousity, I tried wiring it up to a crappy old quad speed CDROM drive. It appeared to work. Even tho the 5v rail was now giving out 10v. I pressed eject, and the tray shot out faster than i've ever seen in my life. It almost took my hand off.
    I gave up after this, thought "sod it", and got straight to work on the laptop. Btw, If anyone has had a similar thing happen to thier sproggy? I'wanna try and fix it for mark 4 (see sig).
    My Setup
    Wow..thats a crazy idea. LOL dont bother im sure you can live without music for another 2 days or so.
    So you want to connect the 0V of the laptop to the +5V supply and then connect the +15V of the laptop to the +20V of the other supply to give you 15V in total. It can work it just that your laptop 0V is +5V above the cars ground.
    Its easy to forget this and connect another circuit that can short your +5V supply.
    And how about the current rating of the regulators?
    Naah leave it...sound too messy.
      Ricky327: U r right, it's a lot of trouble, and it probably won't work well.
      Instead.... I tried wiring the laptop straight upto my car battery today, and it worked! 12v isn`t quite the required 15v, but the laptop doesn`t seem to mind. Needless to say, I'm much happier now, I now have tunes again. I should have some pics soon, I`m currently copying songs onto the laptop as I type this.
      My Setup
        Yeah that should work...I guess your laptop battery will never get charged properly but im sure you dont mind that...you got plenty in your car + the alternator =)
          I've actually ditched the imbuilt laptop battery, since it would never charge - it just seemed like a waste of space. In it's place I got my small 5v PSU for the 40x4 LCD. I just hope it's ok when cranking my engine... we'll have to see. I have yet to take it for a journey.
          My Setup
            I found a circuit that could've saved a lot of trouble. It's the classic crowbar. It's only purpose is to blow the fuse in case of an overvoltage. I have never tried it myself but some say it works.
              Thanx, I think I`ll add it to my sproggy when I get it fixed.
              Still got lots of other stuff to do before MK4 is ready tho...
              My Setup
