Ancillary power consumption
  • Ancillary power consumption
    Does anyone know how much power most usb ancillaries consume? Trying to work out how to spread the load over the hubs evenly.
    BT receiver
    Wifi
    Gps
    DAB
    3g dongle
    Cameras, assume some of these will have external power?
    Cheers
    Should they all not conform to the 500ma usb limitations (well 500ma or under)tho im sure the 3g dongle will be the hungry one.i have one that was supplied with a wall plug..its rated at 500ma but it has router mode also
      They should all be 500mA or under excluding ext. hard drives they like 2 powers usually SNO
        i think if you plugged it on a running computer you can see their real consumptions . there is also a software called "usb device view" which probably can be a lot of help identify each usb properties. i just plugged my 8gb donlge and it gives me 200ma.
        Vw Sharan 2007 1.9tdi || Exide 100Ah
        Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
        Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
        Powered by M2 atx
          Cheers, will give that a go.
