wiring help for a cubid 2699r?
  • wiring help for a cubid 2699r?
    Hi
    I have a cubid 2699r case with dc-dc brick type power supply. I am running a mini itx m10000 board with compact flash to boot os from and a laptop hard drive and dvd-rom.
    How do I wire the case into the car?
    Any help gratefully accepted...
    search(!) and build/get a 12v regulating circuit, plug it into the case instead of the brick, wire it to a switch or a relay.
    My cars
      Basically you don't use the "laptop-looking PS brick" and instead you build a 12v regulator (search for those keywords) and hardwire it into the 2 wires which are hooked up to the "laptop-input looking adapter" which is in the back of the PS inside of the case.
