PC reboots when starting engine
  • PC reboots when starting engine
    For example, when I fill up with gas but leave the key on ON its fine, but when I turn the key to start, the voltage drop causes the PC to reboot. I'm using one of zootjeff's DC to DC power supplies.
    Any ideas on what I can do? would a tank circuit fix the problem?
    24 y/o w/ Silver/Red
    2000 Honda S2000
    http://www.squeezer.net
    ya build a tank circuit
    '98 Explorer Sport
    80% done
      You can try a .5 > 1 farod cap used for car audio to keep the current up while cranking, if that is your problem. 1 farod would be overkill, but half farods are hard to find (for me anyway).
        cool. does anyone know where I can buy the mbr3045 diode and a 25v 22000uF capacitor?
        2000 Honda S2000
          But .. how do turn on your PC? It could alao be a problem with a remote wire off your ignition, pending how you hooked it up.
          I have it wired into the fuse panel under my driver side dash. it has 3 connectors for a spade connector. one is always hot, one is hot when key is turned to ON, other is hot when headlights are on. I have it wired into the one that becomes hot when key it turned to ON.
          2000 Honda S2000
            I found out that my car has a relay that drops power from there while cranking, and I was told of an alternate power source before the relay to use.
            2000 Honda S2000
              most cars cut the acc power wile cranking - my 2000 Civic does this through the key switch.
              You learn a lot when you install remote starters
              Gizmo-
              Techonlogy on Wheels
              http://www.hjnetworks.com/car
                gotta love the Opus for things like this. Build a tank circuit.
                Mine needs to be updated.
