Powering Carputer & Audio System
  • Powering Carputer & Audio System
    Ok... So I have an 03 Jetta... I will be putting in a Carputer, 2 x 10" subs, Soundstream D'artagnan 5.1, 7" LCD...
    I will be using a Opus 90W PSU or maybe just an inverter... Depending oh how backordered Opus is...
    What do I have 2 worry about in my car? How do i provide enough power to my car? I will need to get a better altinator right? I am not sure how much power mine generates... How can I find out or does anyone know? 03 VW Jetta GLS
    XtReMoDs.com
    Carputer Status (Not installed.)
    -VIA M10000 N
    -TM-7002S + TSK (7" LCD)
    -512MB PC2700 DDR
    -40GB 2.5" HD
    -SB Live!
    -Rand McNally GPS
    -DLink FM Tuner
    -XMRPC
    _
    the carputer will be no problem ... 90w only pulls 7.5 amps at 12 volts (yay! i can divide) ... and you won't run that thing at capacity.
    And I wouldn't worry about the subs/amp either... especially with the new car. I don't know the specs for the jetta off the top of my head but i'm sure it will be fine. A 1f capacitor would be a good idea tho ... especially if you're into bass.
    make sure you take lots of pics of your install. the wife has a jetta and maybe i can convince her to let me tear it apart if she sees some pics
    My JeepPC Install
    "there are no stupid questions, just stupid people."
    "it's been agreed the whole world stinks so no one's taking showers anymore"
      I will be taking a lot of pics.. I will be writing an article to go on www.xtremods.com
      I have been talkin to a friend that was telling me that i should be worried about if the altinator will give me enough power... he also said a power cap would be a good idea...
      What will a 1f capacitor do?
      XtReMoDs.com
      -VIA M10000 N
      -512MB PC2700 DDR
      -40GB 2.5" HD
      -SB Live!
      -Rand McNally GPS
      -DLink FM Tuner
      -XMRPC
      _
        capacitors in general store energy with the intent of smoothing out spikes ...
        when you have a high power audio system with large subs, often the subs will draw large amounts of power during peak times (like when you get a real big boom) ... this can draw too much power from your alternator causing your head lights to dim or other strange things ...
        putting a cap in there will store up some energy so when your subs need that short burst it takes it from the cap instead of the alternator.
        again I really think you'll be ok on your stock alternator with 2 subs. i know guys running a lot more in cars your size.
        My JeepPC Install
