inverter packed up
  • inverter packed up
    My 300 watt inverter I brought off ebay has packed up, started making some funny fan noises at first on start up then today it just reboots the pc and keeps beeping.
    Emailed the company I brought it from and they will send me out a new one on reciept of my old one.
    Great service I thought.
    So no carputer for me untill monday next week
    www.fsplanes.net NEW site
    AMD XP 1800+ / 256mb ram ddr / 2 x 60gig hdd / Asus mobo micro ATX / GF-FX5200 / BU 303 GPS reciever / dlink usb radio
    Software:
    Window's XP SP1 / USB Radio / Destinator v2 / Mediacar / 3000 mp3's / 30 movies
    Are you sure you battery is fully charged, because that's the sort of thing my inverter does when the battery voltage has dropped too low. It's a protection against dropping the battery too low to start the engine.
      its prob your pc!
      I have a 300W inverter, by Maxx or something like that, anyway, I bought it for usin with my LCD panel only, but htought I'd test my PC too. The PSU in my pc is rated at 160W output, but it is inefficient and draws up to 600W! i unplugged the monitor, and left the pc at idle, and the inverter didn't beep or anything, but whnever i moved them mouse or opened the start menu, it started beeping. This means that the pc was sucking too much, which prob happened in your case. try using another appliance with the inverer, something that drwas no more than the 300W offered by it.
        Nah, its defo faulty, I have a brand new <6monthsold> 100amp battery, its a massive thing, cost 100.00 / $160.00
        My alternator is pushing out 14.1 volts so even if the battery was shagged the inverter should still work fine.
        It will only show a low voltage when the ignition is off, when the car is running the inverter is powered from the alternator and show never show low power <unless your alternator is broke>
        Ron
        It makes the beepeing noise with car running btw <>
        Software:
          Why are you using it for the lcd panel? is it 240v only? I have a gain 12v screen and its wired direct to a +12v on my car.
          The invertor has powered my pc fine for 2 months, but recently started making noises, at max it shouldnt pull anymore than 250-300watts from the invertor, you may get a spike of 500watts for a few secs on startup, but not a continuous 600watt, there must be somthing wrong with your pc.
          If this new one fails, then I will get a 500watt invertor which peaks at 1000watt. I am running a 300watt psu with an amd 1800xp.
          I think the cold just took its toll on it
          Ron
          Software:
            Ron
            I have an suv so i have the room to use an ultraslim desktop 15" LCD panel, which comes with a 120v plug.
              New inverter arrived and all fitted ok, changed the PSU to 300 watt.
              The new inverter is great, I dont know if anyone else has one ofthese but it only switches on when the power is applied to the device, so you can leave it on indefinatly.
              All that is powered while offline is a green LED
              Much better then the other type I had that was perm powered, and needed to be switched off.
              Cheers
              Ron
              BTW my car is being featured in a magazine next month for all you uk people, so keep your eye open
              Software:
                Which Magazine?
                Pc Format I will let you know nearer the time
                Software:
                  I was expecting a Car Mag, not a PC mag
                  lol well you did ask :P
                  I'm not into the Max Power scene, even though it is modified alot, I would prefer the subtlety of pc Format
                  Software:
                    Maybe I missed it in your posts, but what is the brand/model of the invertor? Thanks...
                      Ring I think it is
                      Software:
