Power DC straigt or Transformer
  • Power DC straigt or Transformer
    Is it best to use a heavy duty transformer? or to use a voltage regulator such as a Cap type system to go DC straigt to the MB?
    Does anyone see engine noise etc as an issue with using transformer based systems? for the Audio/Video?
    If you are talking about DC-DC converters, It all depends on the output current you require. If you use a transformer, you can have a higher current output for a smaller circuit. The alternative is a stack of maxim chip circuits, especially if you are looking at greater than 6A on the 12V line. While the maxim circuits are easier to build, some of the parts are becomming increasingly harder to find for free. The maxim chips are also expensive if you actually buy them. So that is another thing to think about.
    As far as noise is concerned, If you build a transformer based setup with the correct filtering and board design, you shouldn't have a problem with noise. That's what all your home audio and computers use, so why should it be any different in a car?
    Anyway, hope that answered some of your questions.
    * woohoo - 100th post
