shut down controller behaviour?
  • shut down controller behaviour?
    just got my mpegbox shutdown controller and it doesn't seem to be working right
    soon as i give the unit 12v ( which in a car would be constant ) even if the ignition wire is low it gives power to computer ( should'nt do untill ignition goes high ) on shutting down it works fine - but then if i make ignition high again it doesn't turn back on...
    i realise it needs a complete cycle to start working - but it won't turn back on after 1 cycle ( need to disconnect power and start again )
    is this normal - or am I doing something wrong...
    www.digital-car.co.uk - The UK CarPC Forum
    ok just tried again - this time relay came on with power, turnt of ignition wire - shutdown waited alloted time and killed relay - fine. turned ignition power back on - but this time the unit came back on after about 10 seconds, but cannot replicate this again... any ideas whats going on?
      its ok working now - must have been a dodgy variable resistor
