Grounding the PC when using an inverter?
  • Grounding the PC when using an inverter?
    Is there any harm in a setup like this. I have a DC to AC inverter and I wanted to ground the PC to the car. I tested the inverter to see if it did this in its circuit, and it doesnt. I can understand why?....because it an isolates the DC from the AC sides of the circuit.
    My reason for wanting to do this is so I can use the PCs PS 12V lead in my shutdown controller.
    If anyone has any knowledge on this, it would help greatly.
    1999 Ford Contour SVT
    Via M9000
    I think i answered my own question. The converter (i think thats the right term) that came with the PC should also be a isolation circuit. In other words, grounding the PC does not ground the AC side of the circuit so everything should be safe.
    Via M9000
      are you grounding your inverter to the car frame? if so do that and then ground your PSU to the same spot as the inverter. Take a screw that holds the PSU to the case
      '98 Explorer Sport
      80% done
