pw70 + itps = no restart on cranking?
  • pw70 + itps = no restart on cranking?
    Doing some reading on here and other sites, it looks like the pw70 and the itps unit from mini-box.com will work good for my via m10000. However, I have been considering getting an opus power supply. It seems the two setups are very similar but will the pw70 + the itps regulator keep the computer on while the car is cranking?
    The main reason why I like the pw70 plus the ITPS is because its small enough to fit inside the case of the c134.
    Thanx
    James
    No it will not be able to survive while your car is cranking without a tank circuit. look for Shakes schematics i think they use the same regulator as the ITPS.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
