PW70a directly to car battery
  • PW70a directly to car battery
    Has anybody successfully connected up the PW70a directly to the car battery and the EPIA board and is still using it
    The PW-70a doesn't regulate the 12v rail, so that's not a good idea.
      i haven't done it ... but according to Minibox this is ok if you don't have any 12v components (i.e. desktop hard drives or cdrom) as the pw-70a just passes that rail straight through without conditioning it...
      i wouldn't trust it though.
      My JeepPC Install
      "there are no stupid questions, just stupid people."
      "it's been agreed the whole world stinks so no one's taking showers anymore"
        I ran a PW-60 directly off the battery for several months and never had any problems. Like others have said, however, the 12v rail is unregulated, so when the car is running, 12v devices (like hard drives) are actually running at 14v. My hard drive never seemed to mind, but recently I added a 12v regulator circuit before the PSU, just to be on the safe side.
          i've got a pw70 running directly off the battery (well, through a shutdown controller) and have no problems... i don't have any 12v devices though
          Car: 2000 Toyota Celica GT-S
          Mods: Yep
          Carputer: VIA M9000 | Opus 150 | 512MB PC2100 | 60GB Notebook HD | Slim/Slot DVD/CDRW | Audigy2NX | Xenarc 700TSV | (2) DSCustoms DS700HRS (in trunk) | SMC USB 802.11b | CoPilot | DLink FM tuner | Cliffnet
            I've got a HD laying around that has "an imminent failure" message when i POST, so i'll plug that in and use it until it finally bites the dust, or something explodes...hmm. Other than that, i have no 12v componants. I'll test it out when i get things installed, seeing as it'll die anyway, and it's old.
            My Carputer! (More Car Pics at the end)
            2 Kicker Comp 10"
            Epia M-9000, 256 MB DDR, 120 Gig HD
            Lilliput 7" VGA Touchscreen
            Check it out?!
              wonder what would happen if the alternator regulator circuit went oops a little bit fautly, i've known it to happen when a few bulbs have popped along with a few other things. i would strongly reccomend that you do use some sort of protection just in case..
              peugeot 406 HDI GTX Carputer
              shuttle sn41g2,amd2500xp,512 ddr ram
              64 meg agp,gps,dvd rom,autoroute 2004
              media engine 2.0+other stuff
              15" active matrix screen(v nice)
              handtrack mouse+mini usb kb,opus 150w
              sound wired into car audio system
                so, if I have EPIA and laptop HDD (those do not use 12v, as I know) and some use devices, connecting PW70a directly to car battery is OK? will it survive a crank then?
                '93 Opel Vectra A with Custom Dash with 7" lilliput
                VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
                http://zvi.home.ge/pics/?dir=vextra
                  from what mini-box says it will be ok. probably still won't survive the crank tho
                  i think the PW-series supplies shot off if they don't get enough voltage.
                  My JeepPC Install
