Possible Cranking Issue Solution - LM3478/LM3488
  • Possible Cranking Issue Solution - LM3478/LM3488
    I just came around this IC at National's site LM3478/LM3488
    According to the datasheet it should solve all the problems around cranking.
    Please correct me if I'm wrong
    http://www.m2visio.de
    |CAR ENTERTAINMENT SYSTEM
    |Epia m10000 w. 256mb
    |20gb 2.5,slimDVD
    |Morex Cubid 3688+ITPS
    |Lilliput VGA+Touchscreen
    it only outputs 1A. The pt5071 is a better sollution with a output of 1,5A
    And the max1771 + extra mosfet gives 2A (like the sproggy MK3)
    Newbee, sorry for my bad english. lol
    Trying to built a carmp3 systeem
    own psu: max788, pt5071, pt5024
      Well, according to the WEBENCH Live Simulation it should manage 5A
      |20gb 2.5,slimDVD
        hmm sorry, my bad.
        In the datasheet:
        first schema gives an output of 2A, but on a set-up way (and you need a setp-up step-down)
        and figure 12 is a step up and down
        So, you could use it, but it isn't the most easy way. Easiest way: pt5071, but quite expensive: around the $21. Request samples: free, and you will get them, I got 2 of them, tomorrow will number 3 arrive
          And where can I these free samples?
          |20gb 2.5,slimDVD
