Automatic power shutdown?
  • Automatic power shutdown?
    Hi, iv' just registerd on the forum
    Ive been thinking ... is there anyway i can get the power to my carputer to shut down automaticaly after the computer are shutdown? ..
    Maybe its a silly idea .. but im no good at this ..
    //Agonar
    The easiest, cheapest (overall) and best way would be to get an Opus power supply.
    This is a 90 or 150W regulated (very important) DC-DC power supply with adjustable startup/shutdown controller built in.
    Price may look daunting, but when you consider you may go through 2-3 different power/shutdown ideas, the Opus is the best way to go directly from the start
    Welcome to the forums!! Just remember, the is your friend
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
      Thanks ...
      I'll look into the OPUS ... seems like everyone here is recommending it ...
      Anyone know any similar product in Europe? .. Sweden?
        i'd be interested too on a opus power supply..
        agonar.. where are you from?
        i'm from switzerland.. does anybody from switzerland or near switzerland need an opus power supply too? then we could save shipping costs..
        STATUS: planing / building
        Car: 85' Audi Urquattro
        System: VIA EPIA M10000?, GPS, WLAN, DLink Radio
        Display: 7" Lilliput Touchscreen
        Power: 300W DC/AC Inverter, OPUS?
        Sound: 7.1 Dolby Digital with Audigy2 NX
          Don't want to make any spam, but take a look at this forum...
          www.carmedia.org
          There's a moderator there (PT CRUISER) well known here that had organized a group buy for some Opus...ask him, he's from switzerland too...
            Agonar, som jag förstår så är du från Sverige! Kul! Är själv ganska ny här och jag ska bygga mig en Sproggy som power supply. För att sätta på och stänga av datorn så tänker jag koppla in mig på tändningen (tändning på dator på, tändning av dator av) med ett enkelt tidrelä så kan du stänga av strömförsörjningen också.
            / Johan
              www.carmedia.org
              OHOH.. it's french!
              but i'll have a look.. thx a lot!
                / Johan
                japp .. svensk här .... ny här med ... ifärd med att bygga datorn i bilen ... det som jag ser som det största problemet är nog strömmen .... min bil drar mycket ström ändå ... så jag skulle vilja att datorn endast kan startas med bilen igång ... samt att strömmen kan slås av hel till den .... har du några ritningar till Sproggy? .. är det en byggsats? .... vad har du tänkt dig för datorn? skärm? .. *ler* .... får min Liliput i morgon ...
                  Sproggy är en byggsats som du kan köpa av en kille här, Mastero, kolla i power supplies forumet där finns det mycket att läsa om Sproggy. Du har rätt i att strömförsörjningen är det största problemet, men för oss som bor här uppe i norr så kommer även kylan att bli ett problem, jag kommer att sätta i ett par extra batterier i min baklucka och jag kommer att koppla några effekt motstånd till en termostat som gör att temperaturen i datorlådan inte understiger +5 grader. Jag har tänkt att använda en MiniITX som har fördelen med att inte dra så mycket ström, jag har inte bestämt mig riktigt, jag vill veta att jag har ström och kyla problemen lösta före jag köper dem dyra sakerna.
                  / J
                    / J
                    Ok ... jag är verkligen inte hemma på el .. skall vända mig till nån som kan det ordentligt ... har lite killar på mitt jobb ... jag har ett MiniITX kort och en Liliputt skärm ... tänkte starta så .. utan vare sig cd/dvd eller gps .... har dock planer på att dra fram ett usb-uttag till kupén för ett ladda genom usbminne ... tänkte ha datorn i skuffen ... vad har du för bil? ... jag har en BMW 540 .... hur har du tänkt lösa ljudet?
                      Jag har en Saab 95, ljudet har jag redan löst, har kastat ut originalstereon och har satt i en baslåda och ett slutsteg på framsystemet, så jag kan bara ta lågnivån från datorn till slutstegen. Jag tänkte börja med en dator med DVD/CD spelare till och sedan komplettera med GPS m.m. Ska också sätta in en USB kontakt vid förarplatsen så att jag kan sätta i ett minne i.
