Interference
  • Interference
    Initially I'm going to use an inverter to power the pc that I have. The PC is by HP and I'm unable to fit any opus gear to it - well not that I can see that there is an easy way to do it just yet.
    Will I find any problems with interference coming from the inverter over the speakers, and if so, how can I get around this?
    Thanks.
    there are a ton of posts on ground. just ground the inverter to the frame of your car and the wire should be as short as possible then take a screw that screws the PSU into the case and ground that to the same spot as your PSU.
    '98 Explorer Sport
    80% done
      Cheers!! lol, I should learn to look around some posts first
