Mastero Shutdown controller wiring instruction
  • Mastero Shutdown controller wiring instruction
    Can some one help me wire this thing up. There is no label or anything on the PCB. No pre-wire color code so I have to attach the pic.
    Which connection go to which (I numbered the terminals).
    This thing is still in the bag Mastero sent. I am going to hook it up with the Sproggy MK3. Mk3.5 later.
    Mastero? Anyone?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Here you go my friend !
    Cheers
    Mastero
      Mastero, I have questions regarding to this SDC.
      The +5V wire is connect to the mobo ATX switch. Is it the pin that show +5V when the mobo is on right (maybe when it off)? I haven't check the mobo pins yet.
      If the ACC line go off for a moment (when crank the ACC cut off), Does the SDC go to the shutdown sequence? If that the case, I have to use my old method to combine the ACC and the IGN wires together.
        Is this the old style shutdown controller circuit, it looks like the one I have.
        Craig
        Audi S8 supercar
        Modded Xbox 400GB HD
        Rear 7" screen & navplus
        Toyota Hiace Van
        Shuttle PIII 866 256Mb 10GB OPUS powered
        MediaCar & Mappoint 2004
        Custom fit 7" TFT VGA TSK
          The +5V wire is connect to the mobo ATX switch. Is it the pin that show +5V when the mobo is on right .....YES
          If the ACC line go off for a moment Does the SDC go to the shutdown sequence?
          IF POWER IS REMOVED ON THE ACC LINE THEN THE SDC WILL WAIT 0~15 MIN BEFORE SENDING THE ATX PLUSE. AND IF WITHIN THAT 15 MIN IF THE ACC LINE IS HOT AGAIN THEN NOTHING HAPPENS
          SO WHEN YOU CRANK THE ACC GOES COLD FOR A FEW SECONDS THE SDC WILL NOT SEND THE ATC PLUSE.
          Hope you got that \... sorry for the caps
          Mastero
            Craig
            This is the latest version from me ..
            Mastero
              Thanks, that help.
