Power supply help needed
  • Power supply help needed
    Hey guys i currently have a shuttle sv 24 mini pc. I wanna change the ps in it to one of these
    http://www.cougar.com.au/index.cfm?ID=33&Part=9999#
    so i can run it in my car as a mp3 pc.
    Problem is that the current psu is a
    Channel Well Technology CWT-150FATX 150W Power Supply
    Spec of the psu are Below in this pic. (this isnt my ps its off another site but same as my ps but i dont have wires hanging outa mine like this idiot lol)
    Ok well i have looked up some more info on the dc dc power supply
    http://www.xtore.com.au/sub%20pccases21.htm
    Also found this web page
    Its under the dc - dc converter bit on the left of the page.
    Dont like how it says thats its very fussy on the input voltage?
    I am worried that by the power outputs the new dc dc ps will not run the shuttle.
    My shuttle specs are
    celeron 1.1
    20gb seagate hd
    256mb ram
    and 1 extra 80mm fan running inside of case.
    So what do yous guys think?
    Will it run with the new ps or am i wasting my time?
    If i down grade my ps to a cele 566 it only uses like 18watts instead of the 1.1's 30 watts will that help a lot.
    Its only $80 so its a bargain for that price
    I would really like to get it to work cause it woulds ave me from the whole inverter and stuff i have already gone threw.
    Any help will be apreciated thanks guys
    http://austmp3car.tk
    I am also running a shuttle on the Mk-3.5 PSU my advice if you can solder then go for the Mk-3.5 it works great.
    Mastero
      Mk 3.5 ??????
      Yeah im a electrician so i can solder pritty good.
      Most kits i can do
        Holden do a search for mk-3.5 power supply you will find it
        Mastero
          So you recomend i buy a mk 3.5 ?
            I recomend you make one ! Come on guys buying is easy... Build your own..
            All the details are there just make one for yourself
            Mastero
              ok thanks man il have a think about it
                If you decide to build your own Maestro PSU just be aware that sourcing Maxim or Linear Technolgies ICs in Australia is quite difficult >_< I haven't been able to find a supplier that'll do Maxim in less than 100 unit quantities...
                  There's one of the MAX chips available easy enough - but about AUD35 each.... Inductors from Jaycar are AUD3.95 each though which is a nice change
                    $35? >_<
                    That's not from Farnell or something is it..
                      ah ok no worries thanks guy il prob give it a miss and go for a opus
