What Gauge Wire To Use
  • What Gauge Wire To Use
    Hey all,
    Just wondering what gauge wires you all are using, my setup is Jeff's controler, and then 400 watt inverter, I have some 16gauge wire for my ACC line and some pink 12 or 10 that came from lowes but my problem is it will not fit into the terminals I have for jeff's controller. My origional Idea was to run the pink wire a + / - directly to the battery going into jeffs controller and then use simular wire to the inverter. Would I be better off just running the pink to a distribution block and then using the 16 from that?? The terminals are the 3M ones that hold 14 or 16 gauge and can hold 600 volts.
    What would a safe thickness be on the wire? I plan to have amps running in the near future too.
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Just looking at the ratings of my wire to see what they can handle... and I will have probably answered my own question, but any help would be apprecheated
      Here's a general guide to wires that I use. Sorry about the alignment, but the BBS ignores the spacing in the table.
      AWG AMERICAN WIRE GAUGE TABLE FOR BARE COPPER WIRE
      Compiled by Fr. Thomas McGahee tom_mcgahee-at-sigmais-dot-com
      This Table may be copied freely so long as credit is given to the author.
      Originally compiled for use by those building Tesla coils on the TESLA and
      TESLA-2 internet mailing lists.
      Compiled in April 1998 based on information derived from various sources.
      Since there were some discrepancies between data sources, the author has chosen
      not to just copy the numbers found in those sources, but rather to write a
      program that would generate the data based on a Best Fit mathematical model.
      The author has checked the Diameter in mils results against the data contained in the
      MACHINERY'S HANDBOOK, Twenty-First Edition, 1982, published by Industrial Press Inc.
      All numbers shown are accurate to +/- 1 in the least significant digit position.
      Column headings have been repeated to make the list more readable
      AWG = American Wire Gauge size from 0000 to 40
      Dia-mils = Diameter in mils (1 mil = .001 inch)
      TPI = Turns Per Inch [Note that this is for BARE WIRE. Insulation thickness varies]
      Dia-mm = Diameter in millimeters. This was included to help when dealing with metric Coilers.
      Circ-mils = Cross sectional Area in Circular Mils. ( circular mils = diameter in mils squared )
      Ohms/Kft = Ohms Per 1,000 ft.
      Ft/Ohm = Number of feet required for 1 Ohm of resistance
      Ft/Lb = Feet Per Pound
      Ohms/Lb = Ohms Per Pound
      Lb/Kft = Pounds Per 1,000 feet
      *AMPS = Conservative Amp Rating based on 750 circulare mils per Amp
      MaxAmps = Maximum allowable current based on 500 circular mils per Amp. Do NOT exceed this rating.
      AWG Dia-mils TPI Dia-mm Circ-mils Ohms/Kft Ft/Ohm Ft/Lb Ohms/Lb Lb/Kft *Amps MaxAmps
      0000 459.99 2.1740 11.684 211592 0.0490 20402 1.5613 0.0001 640.48 282.12 423.18
      000 409.63 2.4412 10.405 167800 0.0618 16180 1.9688 0.0001 507.93 223.73 335.60
      00 364.79 2.7413 9.2657 133072 0.0779 12831 2.4826 0.0002 402.80 177.43 266.14
      0 324.85 3.0783 8.2513 105531 0.0983 10175 3.1305 0.0003 319.44 140.71 211.06
      1 289.29 3.4567 7.3480 83690 0.1239 8069.5 3.9475 0.0005 253.33 111.59 167.38
      2 257.62 3.8817 6.5436 66369 0.1563 6399.4 4.9777 0.0008 200.90 88.492 132.74
      3 229.42 4.3588 5.8272 52633 0.1970 5075.0 6.2767 0.0012 159.32 70.177 105.27
      4 204.30 4.8947 5.1893 41740 0.2485 4024.7 7.9148 0.0020 126.35 55.653 83.480
      5 181.94 5.4964 4.6212 33101 0.3133 3191.7 9.9804 0.0031 100.20 44.135 66.203
      6 162.02 6.1721 4.1153 26251 0.3951 2531.1 12.585 0.0050 79.460 35.001 52.501
      7 144.28 6.9308 3.6648 20818 0.4982 2007.3 15.869 0.0079 63.014 27.757 41.635
      8 128.49 7.7828 3.2636 16509 0.6282 1591.8 20.011 0.0126 49.973 22.012 33.018
      9 114.42 8.7396 2.9063 13092 0.7921 1262.4 25.233 0.0200 39.630 17.456 26.185
      10 101.90 9.8140 2.5881 10383 0.9989 1001.1 31.819 0.0318 31.428 13.844 20.765
      11 90.741 11.020 2.3048 8233.9 1.2596 793.93 40.122 0.0505 24.924 10.978 16.468
      12 80.807 12.375 2.0525 6529.8 1.5883 629.61 50.593 0.0804 19.765 8.7064 13.060
      13 71.961 13.896 1.8278 5178.3 2.0028 499.31 63.797 0.1278 15.675 6.9045 10.357
      14 64.083 15.605 1.6277 4106.6 2.5255 395.97 80.447 0.2031 12.431 5.4755 8.2132
      15 57.067 17.523 1.4495 3256.7 3.1845 314.02 101.44 0.3230 9.8579 4.3423 6.5134
      16 50.820 19.677 1.2908 2582.7 4.0156 249.03 127.91 0.5136 7.8177 3.4436 5.1654
      17 45.257 22.096 1.1495 2048.2 5.0636 197.49 161.30 0.8167 6.1997 2.7309 4.0963
      18 40.302 24.813 1.0237 1624.3 6.3851 156.62 203.39 1.2986 4.9166 2.1657 3.2485
      19 35.890 27.863 0.9116 1288.1 8.0514 124.20 256.47 2.0648 3.8991 1.7175 2.5762
      20 31.961 31.288 0.8118 1021.5 10.153 98.496 323.41 3.2832 3.0921 1.3620 2.0430
      21 28.462 35.134 0.7229 810.10 12.802 78.111 407.81 5.2205 2.4521 1.0801 1.6202
      22 25.346 39.453 0.6438 642.44 16.143 61.945 514.23 8.3009 1.9446 0.8566 1.2849
      23 22.572 44.304 0.5733 509.48 20.356 49.125 648.44 13.199 1.5422 0.6793 1.0190
      24 20.101 49.750 0.5106 404.03 25.669 38.958 817.66 20.987 1.2230 0.5387 0.8081
      25 17.900 55.866 0.4547 320.41 32.368 30.895 1031.1 33.371 0.9699 0.4272 0.6408
      26 15.940 62.733 0.4049 254.10 40.815 24.501 1300.1 53.061 0.7692 0.3388 0.5082
      27 14.195 70.445 0.3606 201.51 51.467 19.430 1639.4 84.371 0.6100 0.2687 0.4030
      28 12.641 79.105 0.3211 159.80 64.898 15.409 2067.3 134.15 0.4837 0.2131 0.3196
      29 11.257 88.830 0.2859 126.73 81.835 12.220 2606.8 213.31 0.3836 0.1690 0.2535
      30 10.025 99.750 0.2546 100.50 103.19 9.6906 3287.1 339.18 0.3042 0.1340 0.2010
      31 8.9276 112.01 0.2268 79.702 130.12 7.6850 4145.0 539.32 0.2413 0.1063 0.1594
      32 7.9503 125.78 0.2019 63.207 164.08 6.0945 5226.7 857.55 0.1913 0.0843 0.1264
      33 7.0799 141.24 0.1798 50.125 206.90 4.8332 6590.8 1363.6 0.1517 0.0668 0.1003
      34 6.3048 158.61 0.1601 39.751 260.90 3.8329 8310.8 2168.1 0.1203 0.0530 0.0795
      35 5.6146 178.11 0.1426 31.524 328.99 3.0396 10480 3447.5 0.0954 0.0420 0.0630
      36 5.0000 200.00 0.1270 25.000 414.85 2.4105 13215 5481.7 0.0757 0.0333 0.0500
      37 4.4526 224.59 0.1131 19.826 523.11 1.9116 16663 8716.2 0.0600 0.0264 0.0397
      38 3.9652 252.20 0.1007 15.723 659.63 1.5160 21012 13859 0.0476 0.0210 0.0314
      39 3.5311 283.20 0.0897 12.469 831.78 1.2022 26496 22037 0.0377 0.0166 0.0249
      40 3.1445 318.01 0.0799 9.8880 1048.9 0.9534 33410 35040 0.0299 0.0132 0.0198
