Noises with 400w power inveter.
  • Noises with 400w power inveter.
    how come there are noises when i hooked my laptop, xbox to my kenwood dash system with 250w amps thru my aux input by using a 400w inverter, but funny thing is that when i hook up psone, there is no noise.
    wonder everything that have fans will produce moises, and when i hook everything by house hold electric line....there are no noises at all.
    does anyone can help me out with this?
    thanks in advance
    hope i explain it clearly....
    For issues with Ground loops. you may need to ground your Xbox or inverter better. It could also be a cable problem but I doubt that.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
      My problem solved when i found this ground loop isolator at walmart
      http://www.walmart.com/catalog/produ...%3A3947%3A4429
      for $13 in store, it's worth every penny.
      kenwood dash, 400w amp with aux input, hook up my laptop thru the ground loop to aux input, no more noises....
      $20 for 400w inverter and $13 for loop isolator = happy old me...
      hope this help, thanks
      icet
