Startup pulse fix with Jeff Shutdown Controller
  • Startup pulse fix with Jeff Shutdown Controller
    I found a nice and relatively easy fix for those who are using laptops or atx mobos with no auto turn on feature in bios.
    Just add a relay, a cap and resistor. See image below.
    You get a nice 2 second pulse on the ATX wire ( connects to ground) when you first turn on the car. Then the shutdown controller takes care of everything when you turn off the car. Basically you are getting a pulse whenever the switched 12V line goes from off to on.
    This is an old drawing I made of the controller years ago and I just edited a bit.
    Hope helps those of you with that problem.
    If you are looking to build the whole controller go to www.carpc.tk for a detailed description of all the parts.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    jeff's shutdown controller can be modified to add auto turn on by adding a single capacitor to the board - ask him about it...
    all that effort may have been in vain
    www.digital-car.co.uk - The UK CarPC Forum
      No, I have talked to him. If you add a single capacitor and resistor, when you manually turn off the computer, then turning off your car will restart it again. This doesn't happen in my drawing. You only get a pulse when turning ON. The simple relay, cap and resistor can be used for other applications like auto turning on the lilliput etc... If you use a pot you can also vary the timing of the pulse.
      Well thi
      This certainly beats using somethign like a DEI 528T pulse timer relay. =)
      I have some pics of my modified mastero shutdown controller.
      Sorry for the quality, im using my palm camera.
      My TL CarPC ver2
