Does your Opus 90 surive crank and perform shutdown?
  • Does your Opus 90 surive crank and perform shutdown?
    This question has been asked and answered in bits and pieces in a dozen threads. But never (that I could find) in one place. It might be useful if people say what problems if any they've had with the Opus 90 surviving crank and shutting down improperly.
    I've talked to someone who says some of his carputer clients have sporadic problems with the computer not surviving crank and not shutting down properly (10% of the time or so).
    I'm wondering if for most people it's 100% reliable or only somewhat reliable.
    My 90w Opus survives carnks and shuts down properly every time. (knock on wood)
    http://www.arizonasportcompacts.com
      I've not had ANY problems with my Opus, and hence my carputer, since I got it.
      In that, I mean that it survives crank, starts up and shuts down properly.
      Garry
      Co-Developer of A.I.M.E.E
      www.aimee.cc
        Garry
        I just got my opus 90w in the mail today, I downloaded the manual, and looked at the section for shutdown delay... Is there really only two settings one for 10 sec and one for 20 minutes? I hope not, 10 sec seems too short and 20 minutes seems a bit long....
          My 150watt OPUS works perfectly everytime so far. Yes it is only 10 sec and 20 minutes.
          If you want more discrete timing set it to 20 minutes and use software to automatically shutdown / hibernate after a certain amount of inactivity.
          StreetDeck.com Developer (I am Chuck)
          Get StreetDeck at http://www.streetdeck.com
          The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
            Well that means I either have to shut off mediacar everytime, or keep having to wake up the PC when driving longer then 20 minutes. Thats not really an option for me, hopefully my PC will hibernate gracefully within 10 seconds...
              I have a feeling you are misunderstanding the whole concept.
                no, lopan is not misunderstanding it, unless i am too! he's just saying if he follows the advice of "god of cpu" (setting Windows to hibernate if inactive for more than X minutes) then he needs to continually move the mouse or hit a key or something to prevent the computer from going into hibernation because of "inactivity". i assume if Winamp is just running, and you don't do anything, it would still think it's inactive. and if it doesn't think that's inactive, then that option is pretty useless as a replacement for the shutdown controller.
                i would certainly agree that 10 seconds is way too short. i don't think my computer would reliably (every time) hibernate that fast (with 512 MB ram). i could be wrong.
                  Having heard of the Opus concept, which is quite similar to mine, it will survive cranking and do proper shutdown. However, in case of a bad alternator and/or a bad battery, the voltage can drop as low as 5V (according to Ford specifications). My design would not bridge such low extremes and the Opus won't do either I guess.
                  For the shutdown concept similar problems can rise; if someone starts playing with start>shutdown or presses the power button and then during the shutdown period also shuts down the acc. line, then the shutdown control sequence might get messed up. This is a potential problem with my design and probably for Opus as well (in fact, I heard Opus does not really like concurrent existence of the power botton at all).
                  So if you have a healthy car and you don't attempt unusual power-sequencing tricks, then there shouldn't be any problem...
                  Disclaimer; just back from pub at 3:40am local time, just fill in the consequences you experience...
                  white bream
                  working on a trilogy: CARGO - UNIGO - MERGO
                  CARGO = the Car Computer
                  Intel Celeron M, [P]SDC, uBlox GPS, GPRS, WLAN, Silabs FM, RDS, TMC,
                  Dual-audio, Onecable TFT, Microsize: 45 x 108 x 168mm (1.8 x 4.3 x 6.6")
                    I believe the 10 second/20 minute option refers to the time the Opus waits BEFORE starting the shutdown process. After that, the computer can take as long as it wants to hibernate, no hurry. This differs from the ITPS and Mucha shutdown controllers, which shut off all power a short time later.
                    I believe that is what lopan was confused about.
                      I plan on using a three pole switch(from home depot) with my Opus setup to feed the controller the ignition wire(timed shut down), nothing(manual shutdown/prevent startup) and constant feed from battery(stay on/manual startup). Perfect flexibility of power control.
                      '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
                      MII12000opus120~MII12000opus120~MII10000opus150
                      NA~Senao dual 7.4 ant~Orinoco Gold
                      Pioneer~Pioneer~PG Octane-R R5.1MT
                      Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
                        bridger, yeah, that's what i do (was using the ITPS and 120A PSU), and now using the Opus. i really like having that ability to force it to stay on or stay off.
                          OK, here's the skinny on the Opus, because many people in this thread don't understand it.
                          You turn the ignition on.
                          5 seconds later, the computer turns on and boots up.
                          You do whatever you need to do while in the car.
                          If you turn the ignition off, then back on BEFORE the time-out you set on the Opus, it continues working, and it won't restart when you start the engine again.
                          If you don't give power back to the Opus from the ignition when the time-out is reached, it "presses the power button on the front of the PC" (you set in Power Options "When I press the power button on my computer..." to "Hibernate" or "Standby" or even "Shutdown".
                          The computer will start to shut down.
                          The computer, and therefore the power supply, will turn off WHEN THE COMPUTER IS READY. IF the computer didn't shut down and say "turn off power" to the Opus, it will stay on. THAT IS A PROBLEM WITH YOUR COMPUTER, NOT THE OPUS.
                          Garry
                          www.aimee.cc
                            Probably, I was thinking when you turn the ignition off it sends shutdown command immediately then waits 10sec or 20 minutes to cut power... But I get it now... I was a bit confused... thats good to know
