Random Startup and Shutdown with Opus
  • Random Startup and Shutdown with Opus
    Hello,
    I am experiencing some problems (minor bugs) with my Opus 90W. When i turn on the car it takes 5 seconds to start up. Sometimes it doesn't even turn on. and when i take the keyout of the ignition it shutsdown but at random time intervals. Sometimes 10 seconds othertimes a couple of minutes.
    Anybody have any idea of what is going?
    Shutdown time will vary depending on the programs you are running or have run. This is common with all windows machines. I wouldn't worry about that too much. An extra couple of minutes won't harm your car or it's battery. If your computer is not turning on the Opus may be giving you an error, check the tiny little LED on the power in edge of the board and check the error table on the instruction sheet. Maybe you've already done this, but I didn't see that you have.
    http://www.arizonasportcompacts.com
      Thanks. I don't believe (<--- check spelling) in Jeebus either.
      Cheers
