Grounding concern (not normal grounding issue)
  • Grounding concern (not normal grounding issue)
    I chose to remove my pwr supply from the case (pwr supply case) since its much smaller that way. Now the grounding pin for the power cable had a grounding wire connecting it to the case (power supply case). Now that i dont have this case, where should i make this grounding wire go (the case im putting the supply in is plexiglass.) Thank you
    -EVOXTC
    Vehicle: 2003 Mistubishi Evolution
    PC Specs: 1gHz Nehemiah M10000
    512mb RAM
    Windows XP Professional
    80gb 7200rpm 8mb cache HDD
    UI: MediaEngine 2.1
    Ground it to the frame of your car, preferably to the same spot you're grounding your inverter if you're using one.
      so im grounding the 3rd pin from the power connecter to the car? just want to be sure
      -EVOXTC
      512mb RAM
      UI: MediaEngine 2.1
