How to power the PC OUTSIDE the car?
  • How to power the PC OUTSIDE the car?
    Hello,
    Wondering what the best way to power a DC-DC powered car pc is when its not in the car? Do you unhook everything, and then use a AC-DC PS inside the home? Or is their a better way to handle this, maybe with AC-DC converter?
    Thanks,
    Mark
    Like you have the power blocks for laptops. Same idea.
      Thank you,
      Which type of plug does the Opus 150 and 90W PS take, and is there a favorite converter people are using inside the home?
      Thanks,
      Mark
        Currently I have inverter setup in the car, but soon to be replace with sproggy DC-DC PSU. My Mastero/Sproggy 3.0 can't handle the hardrive. Once I have DC-DC PSU, I just use AC-DC PSU inside the house. It's not that complicated and only 2 connections to plug and unplug.
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
          well you only really need to unplug the atx connector and hard drive.. and parhaps a cd/dvd/cdr whatever drive if you have it. so a normal atx supply should be quite the best route to go
          Welcome, cdm.
          You last visited: 09-13-2006 at 02:42 AM
          Private Messages: Unread 0, Total 3.
          Wow.. how things have changed in 4 years. Gone are the days of mcgyver and datalux
            If you are using an Opus, you chould just disconnect the ATX P1 connector from the Opus then put a gender changer on you AC-DC power supply, then hook up your AC-DC with gender changer to the ATX P1. That way you only need to unhook the one power plug.
              What about an AC-to-DC converter like this: http://www.tripplite.com/products/in...ed_dcpower.cfm
              Would these get the job done to run an Opus supply? How many amps does the Opus need to run?
              Phillip Hullquist
              I entertain people through adventure movies.
              www.11visions.com
                Uh, well... power = voltage x current... so 90watts / 12 volts = 7.5 amps. It's not so hard to just swap out the power supply though.
                http://www.arizonasportcompacts.com
                  For 150W Opus:
                  AC to DC Supply
                  120V Input
                  12~15 Output
                  10~12.5 Amps
                  Right?
                  VIA Epia II
                  256MB 266DDR Ram
                  90GB Wester Digital
                  Bluetooth/Deluo GPS
                  Lilliput 7" Touchscreen
                  Mazda 6 Carputter > Click Me!
                    While my box is not in the car, I use the AC-DC power adapter that came with the case (morex cubid 2677R) which provides +12V DC:
                    I replaced the existing female power plug and wiring with a new plug wired to the Opus. I then added another female power plug for the remote turn-on signal. I added an SPST switch with a diode to override the remote turn-on signal. When I bring the box inside, I simply connect it to the AC-DC power adapter and flip the switch.
                    Code:
                      O  +12V         O  head unit   .----------.
                      |               |              | DC-PS    |
                      |               o--------------o Remote   |
                      |               |              | Turn-on  |
                      |               \  switch      |          |
                      |                \ SPST        |          |
                      '---------------o--------------o Vin      |
