Low battery Cutoff Voltage ??
  • Low battery Cutoff Voltage ??
    What according to all Should be the Low voltage cut off Volt be ..?
    a) 11.0vdc
    b) 10.5vdc
    c) 10.0vdc
    Please give your opinion.
    Mastero
    for me 10.0 vdc will do.
    :: MSCAR ::
    .:: Multimedia System Car ::.
      a) 11.0vdc
      b) 10.5vdc
      c) 10.0vdc
      Mastero
      My vote goes to b) 10.5Volts
      frenchnew
        I go for 10.5. If adjustable, that is perfect.
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
          Absolutely ideal would be 2 stage
          9 volts for 1 second (for guys with weak battery's/ hungry starters) and 11 or so for normal so you don't drain the battery sitting in the parking lot.
          I realize that would be hard, but it would be ideal.
          2002 Golf TDI With Phatbox . Blue 87 Supra Needs to go, Grey 89 Targa with stock Radio.
            I would say 10.5 is good for me
            VOICES Status : Rework in Progress [||--------](20%)
            Preview Version at http://voices.techworldonline.com
              Thank you everyone for your time .
              Mastero
                There are some applications where you would want the low voltage cutoff at 8v
                Think deep cycle battery, problem is most audio amps also have a cutoff voltage.
                TruckPC - gutted, being used for test setup
                BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
                BlazerPC - Nexus 7 with Timur's USBROM
