Solved: USB bus stays powered after shutdown
  • Solved: USB bus stays powered after shutdown
    Hi All,
    We had a thread on this the other day, and the solution I implemented is slightly different than the one that was proposed.
    Problem: USB bus stays powered even after Opus shuts down computer, thereby draining the battery. Secondly - I needed to power my USB hub.
    Solution: I have 6 USB ports on the Shuttle, but unfortunately the 4 on the back of the computer are integrated into the board. The two front ones are not, and therefore have a cable that connects the ports to the mobo. Here - we spliced in a relay for the two USB ports (splicing into the power lines) that is powered by the molex connector. So - power is supplied to the bus only when the hard drive (for example) is powered. In essence, as soon as the computer shuts down, so does power to the bus. The second relay is essentially the same, except that it's for the 5v line that runs from another molex connector to the USB hub. So - power is supplied to the hub only when the computer is on.
    It's essentially like the solution that was drawn up on the other thread, but note that no diode's, and therefore no drop in voltage, were necessary to do this. It works like a charm.
    Thanks for all of the help and suggestions.
    -Per
    Just curious, why did you decide not to use the relay?
      Not sure what you mean. I used two relay's, but no diode's.
      So, relay 1: from HD connector to 2 front USB ports (power down ports when computer shuts down), and
      Relay 2: from HD connector to USB hub power (power down hub when computer shuts down).
      -Per
        S4Per read shchua post #31 on :
        http://www.mp3car.com/vbulletin/show...t=24507&page=3
        Its a protection diode and you do need it...theres no voltage lost concern in that.
        You dont wanna risk damaging your PSU, HDD or anything thats connected to that relay coil...I did say dont miss that diode...and do connect it the right way.
        Glad you got it working anyway.
          a-ha...thanks much for the pointer. looks like i'll need to get that in there. thanks again!
            Do you need BOTH 5V power sources? Would this work with using only one relay on either the hub external power supply or the 5v power off the motherboard USB connector feeding the hub? Thereby eliminating one or the other power source?
            System:
            Epia M1000 w/512MB PC2100, Xenarc 700TS, ATI 7500 PCI, OPUS 150 PSU, 2.5 40GB 5400 HDD, 802.11g PCI, Slim Slot DVDR,
            Gyration RF Kybrd, OBDII adpt. + sftwr, XP pro, iGuidance/Royaltek GPS NAV, XMPCR, Kenwd KAC-8401 4 chnl amp, 10" pwd sub
              I needed to do 2 things:
              1. Make sure that when the computer is off, no power gets supplied to the bus, and
              2. Make sure that when the computer is off, no power is being supplied to the 'external' power supply of the USB hub.
              So - two different things, therefore 2 relays.
              HTH,
              Per
                HTH,
                Per
                Others who are considering doing this may want to look for a DP (Double Pole) relay. In this application a DP would do the same job as two relays, but would save some wiring etc. You would connect the bus to one pole, and the PS to the other.
                Is anyone doing anything similar to this to control the power to their monitor? This way if you wanted to have the screen on when the car is off, but the computer running, but not supply power to the monitor to save the battery you could.
                  S4Per,
                  Do you HAVE to have two seperate sources for power and why?
                  MUSC5vette,
                  I currently use a relay to power up/down my LCD display.
                  System:
                    http://www.maplin.co.uk/Search/results.asp?CartId=040417214534929&Level=1&Menu=18 &Name=Relays
                    As MSUC5Vette advised :
                    Yes use DPDT relays on the list and save a diode too
                      OK, maybe I'm dumb, but wouldn't it be easier to just use a powered USB hub (12 volt of course). Hook the powered hub to the ACC line, so it's only on when the car is on or in accessory mode. You'd also need to cut the USB cable that runs from the motherboard to the USB hub, severing the 5v feed, but leaving the data connections. That way no power is drawn from the motherboard, only the ACC line for USB devices plugged into the hub. This way you could plug your GPS (for instance) directly into the motherboard, so it's always powered, and your USB DVD drive into the hub, so it's only powered while the car is on.
                      Does that make sense? Or am I missing something?
                      TIA,
                      Tom
                      So far:
                      M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
                        NO
                        Because you will loose the power to the USB devices as soon as you take the key out. Shutdown controller do have some delay before shutting down as soon as the ignirion is gone.
                        What if the PC is trying to write to the USB HDD before shutting down? but you already took the power away from it?
                        I guess, yes it can work for some setup
                          tom2112,
                          Thank you for posting what I was trying to ask.
                          Ricky327,
                          NO ...
                          Thanks for clearing this up.
                          System:
                            NO
                            just wire it to your car alarm then when you chirp your car its off and when you chirp chirp is on simple and easy and i really hope most of you have a car alarm of some sort with this expensive hardware ......
                            I want to wire my car computer to my alarm hmm adding a usb hub lets see
                            1. Chirp Chirp ( ON ) > turn on carputer with the Power-SW pinouts + a relay to turn on the usb hub.
                            2. Chirp ( OFF ) > turn off carputer with the Power-SW pinouts + a relay to turn off the usb hub.
                            Also if you didn't want to wire it directly to the unlock/lock function of your car alarm alot of them have a accessory feature like the clifford ones do. **** you could even do this! one to turn on / turn off and one to reset the carputer.
                            How cool would that be! Just make sure you arm your car most of us do but you could also wire a itps so if forget it kills the power.
                            Cool also if your in your house and you want to sync some music over just power it on (remote start would be better for this though) and copy over and power down.
                            2005 Ford Mustang GT <- - - UPDATED PICTURES
                            2003 KAWASAKI Z1000 - CUSTOM MODZ
                            MBK (AIM = IllMBKllI)
                              The DSSC circuit will fix this easily...
                              The DSSC startup / shutdown controller will solve this easily. It has a master relay that completely pulls power to the PC. It solves these USB issues.
                              You can see it over at:
                              http://www.dashpc.com/
                              Click on the DSSC circuit link.
                              Best regards,
                              CB
