12V PSU and Shutdown controller for Gigabyte Brix
  • 12V PSU and Shutdown controller for Gigabyte Brix
    My next generation of CarPC will use a MiniPC; specifically a Gigabyte Brix with a Celeron J1900 CPU. This little box needs clean 12V in and that's it, which seems simple enough.
    My only issue is shutting down. My current carpc is a netbook with a built-in battery, so it can sleep/hibernate when the car ignition is off, but this MiniPC won't have that option.
    Is there anything in the mp3car store that will help? I don't know if the PicoUPS, the DCDC-120W or a simple Micro Shutdown Controller are all I need.
    http://sticksout.blogspot.com
    So I've bought a DCDC-USB 100W power supply (available from the store here, and elsewhere). It has two wires which need to connect to the BRIX's power switch (i.e soldering a connection), but that's it. The PSU connects directly to the car's battery and detects ignition voltage to send startup/shutdown signals based on the timer settings, which are set by onboard jumpers. If battery goes below 11.2V it cuts off all power completely.
    Power output can be set from 5 to 24V, with 12V as a default. The output plug is a Mini-fit Molex connector, but that can easily converted to a barrel jack as found on a BRIX or NUC or other mini-pc.
    I'll try it out and report back for posterity.
      So how did you go ?
      If I upgrade my VIA-PicoITX board I'll need this instead of the standard ATX multi-voltage supply from my M2-ATX startup/shutdown controller
      VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
      Build 90% Apps 50% Install 10%
