Shutdown controller options?
  • Shutdown controller options?
    I need a controler that will simply control a master relay and pulse my power button upon ignition on and ignition off. Jeff Mucha seems to have the best controller for my needs, does anyone have anything like it. He seems to be tied up. This is the last component i need for flawless operation.
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
    PM Mastero, the 2 are basically the same.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      Get the ITPS from here. Works great.
      Edit: You can attach the output of the ITPS to your master relay if you don't want that to supply power to your setup.
        Be aware though that the ITPS shuts down after about 30 seconds when ignition is lost, whereas the shutdown controllers have programmable timers. (well pots) and can give you upto 30 mins before the PC shuts down.
        Craig
        Audi S8 supercar
        Modded Xbox 400GB HD
        Rear 7" screen & navplus
        Toyota Hiace Van
        Shuttle PIII 866 256Mb 10GB OPUS powered
        MediaCar & Mappoint 2004
        Custom fit 7" TFT VGA TSK
