Any experience with Dell PSUs?
  • Any experience with Dell PSUs?
    I'm working on a non-mp3car related project where I need the motherboard to come on when power is applied. Typically, the easiest way to accomplish this is to short the PSON wire (pin 11) to a ground wire (pin 12) coming from the PSU.
    But silly old Dell and their proprietary PSUs are causing me troubles. I found the PSON pin and I can make the power supply come on with power is applied, but the motherboard won't turn on. Any thoughts, theories, or other speculation as to why this might be?
    Pinouts:
    1 +5 VDC (red)
    2 Common (black)
    3 +5 VDC (red)
    4 Common (black)
    5 PWRGOOD1 (orange)
    6 +5 VFP (purple)
    7 +12 VDC (yellow)
    8 –12 VDC (blue)
    9 Common (black)
    10 Common (black)
    11 PSON#2 (brown)
    12 Common (black)
    13 Common (black)
    14 Common (black)
    15 –5 VDC (white)
    16 +5 VDC (red)
    17 +5 VDC (red)
    18 +5 VDC (red)
    19 Not connected
    20 +5 VDC (red)
    1 Pin 5 — PWRGOOD is a status signal generated by the power supply to notify the system that the DC operating voltages are within the ranges required for proper system operation.
    2 Pin 11 — PSON# is activated by pressing and releasing the power button while the power supply is in standby state. Activating PSON# connects the power supply’s PSON# input to ground, thereby switching the power supply to full-on condition.
    Don't Click
    As you have noticed, DELL are a pain in the <insert derogatory word of your choice here> with their 'special' PSU's. Do a search on I belive I once came across a site that sold or described how to use a normal ATX with a DELL.
      Well I just discovered that the motherboard still needs that momentary short between the pwrswtch pins. AWESOMETASTICLES! I've seen articles like what you're talking about, but it now looks like I've once again been defeated by the almighty Dell EE Retard Brigade.
      I guess I'll just break down and buy an epia or something. Feh.
      Don't Click
        Don't fret it I have a compaq EN SFF, which also has a proprietry PSU, I also tried matching the wiring but no luck. So I am replacing with a MicroATX board and doing a custom fit rather than just plonking th PC in as I have now.
          I am adding this ATX pinout below, just so someone doenst think the one above might be an ATX pinout, i almost did. I did a search on this site for the PSON wiring and came up with this thread.
          ATX Power Connector
          Pinout
          Please note that this connector's pins are numbered oddly - not in the normal manner Instead it is numbered like the odd-ball Sub-d connector. Probably someone who had not laid out many PCBs did this. (A normal approach would have been to number it counterclockwise looking at the sockets or clockwise looking at the pins)
          Pin Signal Wire Color
          1 +3.3Vdc Orange
          2 +3.3Vdc Orange
          3 GND Black
          4 +5Vdc Red
          5 GND Black
          6 +5Vdc Red
          7 GND Black
          8 PWR-OK Gray
          9 +5Vdc
          VSB
          standby Voltage Purple
          10 +12Vdc Yellow
          11 +3.3Vdc Orange
          {brown is 3.3Vdc
          sense]
          12 -12Vdc Blue
          13 GND Black
          14 PS-ON Green
          15 GND Black
          16 GND Black
          17 GND Black
          18 -5Vdc White
          19 +5Vdc Red
          20 +5Vdc Red
          Dual Lilliput's 70NP/C/T
          Syntax SV266AD KT266A
          AMD Athlon XP 2000
          Viking 256MB DDR
          D-Link Wireless 802.11B
          Seagate 120GB
          OrbitMicro 250W DC/DC converter
          SII Wireless Audio Link
          Digimoto OBD-II
          Earthmate GPS
          BU-303 USB GPS
          D-Link Bluetooth
