Is 8 gauge wire heavy enough? Amp + PS
  • Is 8 gauge wire heavy enough? Amp + PS
    Would it be safe to power an off-brand (Sound Storm) 400 watt peak (100x4) amp and Mastero's MK-4 power supply off one 8 gauge supply wire? The computer I plan to use for the time being is fairly low power hungry (comes with a 60 Watt external supply), but I may upgrade at some point in the future. I am considering powering the 7" LCD through the PS but haven't decided yet. I will also be powering an external slim line CD-Rom drive.
    I will not be using a head unit.
    If this is not safe or recommended, what gauge should I run for the MK-4's separate line?
    (sorry if this has been addressed before; I searched but came up with countless results that didn't really answer my question.)
    Check the manual on the amp. they usualy tell you what the recommended gauge wire is.
    4 or 8 should be fine. I ran 4 just for grins (very expensive though)
      more than adequate
      [H]4 Life
      I'm a lesbian too.
      I am for hire!
        8 is plenty
        My Carputer! (More Car Pics at the end)
        2 Kicker Comp 10"
        Epia M-9000, 256 MB DDR, 120 Gig HD
        Lilliput 7" VGA Touchscreen
        Check it out?!
          The manual for this amp is fairly worthless, it's only 20 pages and covers every model they make, up to a 1300 watt. It does say to use 8 guage wire. I just wasn't sure if I could also run the DC-DC PS on it.
          Thanks for the replies, everyone.
            The wire guage you need for any particularly application is based on 2 things. The amount of current you'll draw and the distance that your drawing this current over. The more amps you draw and the longer you need to draw it over, the lower the gauge wire you will need. You can calculate the exact gauge that can be safely used based on the properties of the wire your using but the easiest way is to just look it up in a table like this one:
            If you need some good cheap cable, AllElectronics has high-stranded 4 guage for around $1.00 a ft.
   Developer (I am Chuck)
            Get StreetDeck at
            The Official StreetDeck Forums have moved, please visit us at for official support for Streetdeck.
