Thoughts on an ITPS Override Switch
  • Thoughts on an ITPS Override Switch
    Just realized that my post might not be seen by the experts so as not to be repetitive, please see details here:
    http://www.mp3car.com/vbulletin/show...6&postcount=40
    Don't Fear The Gurkey
    Click here to check out My Setup
    I'm planning on having a simpler system for controlling the power in my setup.
    I'm going to have a switch for me to control where my OPUS power supply gets its control signal from. One switch position will give the OPUS the signal from my ACC line off the ignition, the other switch position will give the OPUS a constant signal. That way I can have the computer always on, or only on when the radio (ACC) is on.
      Anyone have an answer?
        Wkolodny,
        Unless I'm missing something, wouldn't something like the attached diagram do the trick? You could even combine the two switches into one 3-way switch.
        MikeH
          ^ You can't do this with ITPS. It won't survive the crank, remember?
          You can do this with OPUS because it allows crank. If you have ITPS, you can only do one switch (switch 1). That's what I have. It works great.
            But, switch 2 will allow you to trigger the ITPS without starting the car.
            Epia M10000, Custom enclosure, Starvision SP-VGAT, Linksys WUSB54G, Delorme Earthmate, Windows XP
              I have a 3 way switch ON-OFF-ON. The middle position is OFF. Either up or down is ON. On Top I connect to the car ACC/IGN line. The bottom connected to constant power/battery. If the switch Top possition, the PSU get power as with the key. On bottom, it will run till the battery drain.
              Y2K Accord Dell GX150
              EmoRebellion is a SCAMMER
                NaFooEsi:
                My PC survives the crank 4 out of 5 times.
                Thanks Guys. Thats what I was looking for. I was overthinking the problem. MatrixPC do you have a link to the switch you used?
                  Nop. I bought it at a local Electronic store.
                    If you have a Radio Shack nearby, here are 3 sizes (any will do since current is low).
                    One
                    Two
                    Three
                    SeeYa! -Jim-
                      Here's a simplified drawing of the single pole 3-throw switch configuration.
                      MikeH
                        That looks good MikeH. Only question I have is why would you wire the thrid connector to ground? Shouldn't it just be left open?
                          The center terminal of the switch is connected only to the ACC input of the ITPS. One of the outside terminals is connected to the car's ignition "on" (or ACC) point. The other outside terminal goes to 12V.
                          When the switch is in the middle position, the center terminal goes to neither the ignition nor the ACC, so the ITPS does not run. In the other two positions, the center terminal is connected either to the ignition or the +12V depending which way you flip it. It is not necessary to ground the ITPS ACC input in order to switch the ITPS off, all you need do is open the circuit.
                          SeeYa! -Jim-
                            Oh, and the switches I posted links for are SPDT w/center-off (not SP3T).
                            SeeYa! -Jim-
                              Hi,
                              this and' the scheme of as I have connected me my carputer.
                              And' also a circuit antibump for the boxes connected to the audio amplifier.
                              In this way they are connected after once setting with V1, and so' they are eliminated the bumps that I had in lighting and turning off of the carputer on the boxes audio.
                              Made a will and work correctly
                              Excuse me, the text in the scheme and' in Italian, I live in Italy
                              Mauri
