Getting power into Opus
  • Getting power into Opus
    Ok, so my Opus arrived this morning, albeit with a minor problem.
    From what I can see on the Opus website you get power into it from the 3 pin connector, the one thats a little like a molex. Problem is I aint got one in the package.
    Can some one clarify if that is the lead needed to supply power?
    cheers
    Which OPUS PSU did you get? 90W or 150W.
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
      150w
        Yep, you need power in on those three cables.
        Call up whoever you got it from, and say that you didn't get one, i'm sure they'll send one out ASAP.
        Then, check all the packaging and eventually find it, then call up supplier and tell them to not send it out, as you found it
        Garry
        Co-Developer of A.I.M.E.E
        www.aimee.cc
          got it off ebay, and the guy aint replying to my emails, barsteward
            Well you could always take it apart and put on a different connector. Also, look up the instructions for the Opus (around here somehwere). I believe the part number for the connector is listed.
            2004 4runner
              ill have a look-see for the instructions/part numbers, where do i get it from then though?
                If you can, take a picture of the connector and somebody might be able to help you.
                Dual Lilliput's 70NP/C/T
                Syntax SV266AD KT266A
                AMD Athlon XP 2000
                Viking 256MB DDR
                D-Link Wireless 802.11B
                Seagate 120GB
                OrbitMicro 250W DC/DC converter
                SII Wireless Audio Link
                Digimoto OBD-II
                Earthmate GPS
                BU-303 USB GPS
                D-Link Bluetooth
                  if you get desperate you can solder bare leads right on the pins
                  2004 G35 Coupe project
                    It's probably a molex part. www.molex.com. If they won't sell it to you direct, they can probably tell you who will.
                    2004 4runner
                      Mating Plug: AMP; 350766-1
                      Crimps: AMP; 640310-3 qty 2 and 350919-3 qty 1
                      I just checked and the connector and pins are available from digikey. Just type in the part numbers above into their search form.
                      2004 4runner
                        thanx rando
