Will leaving Windows in Standby drain battery?
  • Will leaving Windows in Standby drain battery?
    Hi,
    I starting to get tired of windows hibernation. I also use a mac laptop, and if you have too, you'd know how nice it is to be able to sleep and wake in under 3 seconds. I'm wondering if windows uses about the same power for standby mode as macs use in sleep mode? I can have my 17" powerbook sleep for around a week on its internal battery.
    Yes, standby drains the battery slowly, and the amount of time it takes depends on the battery and the laptop. My Vaio can last a few days on standby.
    Chrysler 300 - Fabricating
    http://hallert.net/
      my understanding of windows standby is that it shuts down everything it can (screen off disks spin down, prehiperals powered down), but keeps power to ram and cpu. But yes, it will drain the battery. If you absolutely cant wait the few extra seconds to resume from hibernate, you may consider putting a second battery in your car to prevent it from draining main battery.
      90% Done
      60W DC-DC & shutdown controller
      Via C3 800, 512mb Ram, HDD 75GB IBM Deskstar, 5.6" In dash Dcustoms LCD w/ 3m USB Touch setup
      Rockfors 400s 400W amp,2x 10" Rockford Subs, Sony CDX M730 Head unit
      All in a shiny White 2000 V6 Mustang
      Click here to visit my NEW PhotoAlbum
        I've gone 4 days so far with my PC in Standby (using a 150W Opus) and the car has started perfectly fine
        I'm sure it can go a lot longer, but 4 days is the most i've gone without using my car, so it's the longest i've been able to test it for so far
        Standby will shut off power to everything but Memory (hdd, screen, cpu etc)
        Garry
        Co-Developer of A.I.M.E.E
        www.aimee.cc
          And you have everything powered by the opus right ?
          Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
          http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
            S3 standby mode on my computer only consumes twice the amount of power as the computer does when its off. The computer consumes very little power when its off so putting it in standby shouldn't effect your battery too much. I'm not sure how much the different modes of standby consume though.
            StreetDeck.com Developer (I am Chuck)
            Get StreetDeck at http://www.streetdeck.com
            The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
              does hibernate use any power?
              mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
              Total = $746....Carputer = Priceless
                No, it writes the memory to the harddrive and then shutsdown.
                  standby still keeps the fans running though.
                  even when you have the machine "shut down" it still consumes power. pci bridge and usb still are on. my ps2 mouse still lights up on LED when machine is shut down.
                  if you really want no power consumption, install a kill switch
                    Doesn't keep the fans running on mine. Each setup WILL be different.
                    Yes, it will still send power to the PS/2 ports (if you've enabled wake on ps/2 event) and the network port (if you've got Wake On LAN enabled) and the USB ports if your motherboard is designed to not fully shut down power to them, but in Shut-down/hibernate mode (unless you completely kill power) you will still be using some power, for the wake-up events, but it is miniscule (probably about the same as having an alarm on and set. Standby will use about twice this to keep a little power to memory, but unless you are not using the car/computer for weeks at a time, it is so convenient to have a 3 second boot-up and a 2 second shut-down
                    Garry
                    www.aimee.cc
                      hmm really... do you have your fans on the molex? mine are just going onto the case fan 3pin connector on the mobo. if i could shut the fans down, it'd greatly help. should really install an inline ammeter to do all of this. anyone konw where to get one?
                      edit: what am i saying inline ammeter?!?! ammeters have to be inline hehehe.
                      does this look cheap (quality)?
                      http://www.surpluscenter.com/item.as...tname=electric
                        I measured 2 amps when the PC is in Hibernate but this will really depend on your motherboard.
                        http://www.mp3car.com/vbulletin/showthread.php?t=26460
                        gaphix.com
                        MSI KM4M MicroATX, Duron 1.6, 512 Micron 2700, WD 80 7200 8mb, Pioneer 120S, M-audio 7.1 pci, Targus USB 2.0 hub, 3com 11a/b/g pci, PNY FX5200 AGP 64mb, Lilliput 7"
                          Hibernate or Standby?
                            Hibernate...I'll do a Standby test tonight and let you know. =)
                            gaphix.com
                              whoah 2amps? that's alot with everything except the minimal motherboard powered down
